Took apart my Classic II nearly 10 years ago for repairs. It had no sound and RTC didn't keep time across power shutdown. Back then I replaced all the chemical capacitors (a couple of lifted pads/traces with some wire repairs) along with a fresh battery. Sounds came back, but RTC still lost power across power shutdown. Left it that way for 10 years.
Decided to repair it again this weekend. Lithium Ion battery still had good Voltage (3.6V). Found some SE30 circuit diagrams for RTC power supply. Pretty simple circuit design from the backup battery end on the SE30, I'm guessing Classic II is same or pretty similar. However, I couldn't find the diode and resistor from the + circuit side of backup battery (D1+R27 in the following SE30 diagram)
http://museum.dyne.org/gallery/apple/stuff/mac/andreas.kann/SE30_P4.GIF
Does anyone have a Classic II schematic?
I did find the contact point between D2+C50, a friend suggest we can easily wire up a diode + resistor from battery + to this contact point.
