SCSI Terminators: Determining Passive vs Active
jmacz
Everything I've read about the filter says that it provides termination capacitance. The service manual mentions it's needed for Apple drives shipped before March 19, 1990 and third-party drives. There are a bunch of notes about it in this doc too. I'm guessing that piece would be harder to disassemble...
Sounds like the answer to the question I had about internal termination in the other thread is that filter. But interesting that the doc @dougg3 linked keeps stating the IIfx takes only one internal scsi device and that the filter goes between the scsi cable and the drive. I thought you could have more than one internal device (I am running two) and if so, where would the filter go? between the cable and the first device or between the cable and the last device (Ie the one with termination enabled)?
David Cook
Maybe it just adds the 2.2uF and 0.01uF caps just like what you pointed out in your other post?
Ding! Ding! Ding! Give this man a prize.
I just broke out my LCR meter and took another shot at measuring the 'filter' portion of the parts. Previously, I had been testing signal pins between terminator power and ground -- assuming a change in inductance, capacitance, or resistance would show up there. This time, I just sort of randomly tested pins.
Between pin 26 (terminator power) and pin 24 (n/c) there is an embedded 2.2 uF capacitor. And between pin 26 (terminator power) and pin 28 (n/c) there is an embedded 0.01 uF capacitor. It is weird that they chose the no-connect pins rather than between terminator power and ground. But, it explains why they wired ground to the n/c pins on the 'terminator' portion of the parts -- to connect the capacitors.
These capacitor values are the same values as Apple uses on their IIfx black terminator and newer gray passive terminator.
Based on figures 11-5, 11-7, 11-8, and 11-9 from Apple's hardware guide, plugging the 'filter' onto an otherwise empty internal SCSI port on the:
Macintosh II and SE: Will connect the capacitors to ground and enable them.
Macintosh SE/30, IIx, IIcx, IIci, IIfx: Will not connect the capacitors to ground
Adding an internal drive or internal terminator which contains traces connecting ground to pins 24 and 28 will also enable the capacitors. This is the most common case.
Apple's recommendation to plug the filter nearest to the internal drive is appropriate. You want the capacitors nearest to the switching signals to reduce noise. Farther away will provide some benefit, just not as good.
I assume newer drives, terminators, and Macs include adequate capacitors, thus diminishing returns for the added capacitors of the filter.
jmacz
@David Cook what if you have multiple internal drives:
Internal Connector <-> Drive A (middle connector on the ribbon) <-> Drive B (last connector on the ribbon) with Termination jumper enabled
In this case does the filter go between the middle connector and Drive A or between the last connector and Drive B?
David Cook
The filter's purpose is to help the terminator. The capacitors provide little fast-acting reserves of terminator power.
In your example, attach the filter to the last connector (Drive B) with the termination jumper enabled -- because you want the filter nearest to the terminator because it helps the terminator.
In Apple's example without an internal drive, a little terminator cap is placed on top of the filter. There again, the filter is nearest to the internal terminator.
Newer hard drives already have the capacitors and/or use active termination. The filter is not needed in that case, but won't hurt.
dougg3
Yay! Thanks for confirming. It all makes sense.
For what it's worth, pins 20, 22, 24, 28, and 30 are all GND on a random Quantum hard drive I just tested. Seems like there is a bit of varying info out there about some of those pins. They're also wired to GND on SCSI2SD, ZuluSCSI, etc.
David Cook
Here is a Mac Memories DataMate DM800-09-R active SCSI terminator making the rounds on eBay.
This is an external terminator with a Centronics 50-pin connector.
The circuit is the usual 2.85V voltage regulator with 110 ohm pull-up resistors (laser trimmed in this case). The mix of capacitor values is slightly different than normal, but perfectly valid.
The regulator is a Burr Brown REG11172 -- specially targeted for this purpose.
