Classic II constantly reboots/chimes
solidpro
I took a video - here - can anyone diagnose why?
I've recapped both the analogue board or logic board. Anyone know what would cause it to do this?
cheers
Nixontheknight
cheers
every time it reboots, it sounds like the power supply is rebooting due to overcurrent, did you replace all the capacitors on the analog board or just some of them?
3lectr1cPPC
There's an octocoupler and a couple of resistors I believe that fail on the Classic series analog boards. I forget exactly which ones, someone else can point that out. That may be a good place to start though.
joshc
A heap of components can fail on the analog board - sometimes just a recap isn't enough. Also PP1 (?) can be adjusted to adjust the voltage output by the analog board. Best to check voltages first and see if they're stable or not, my guess is not based on the behaviour of the machine.
bibilit
Probably the 5 volt line too low.
Replace both diodes Dp3 and DP4… always a weak point.
kupouzar
Take a look at this thread. Looks like a low voltage issue. I believe the analog board in the Classic II is similar (if not the exact same) as in the original Classic.
Edit: of course I meant the analog board, sorry
Take a look at this thread. Looks like a low voltage issue. I believe the logic board in the Classic II is similar (if not the exact same) as in the original Classic.
Hum, they should be pretty different. The Classic is a cost reduced SE. The Classic II is based on the LC family.
VeryVon
Looking at the construction of the Classic II vs say, an SE you can clearly see the cost-cutting measures. Not a fan of this.
The Classic II (a.k.a. "Performa 200") was produced from approx 91-93. Steve Jobs was absent from apple from 85-97. Things that make you go "hmmm" ...
p.s. I've slaved over a Classic II, replacing and repairing many things, and it's still a bit flakey. I think the SE and Classic are a bit more robust. I really want to try my hand at booting an original Classic (not Classic II) from ROM some time, but haven't come across one for the right price.
solidpro
Sorry for slow reply. I had written a post-it note on the front saying I needed to start checking Diodes. Basically I went to sell this on as faulty and then decided I needed to wait until I had the time to do one more pass before giving up. Does anyone know a source of other common failures on the board? I am pretty savvy at doing all the capacitors on both boards but I don't have the knowledge to know exactly what diodes etc to buy to replace them. I do know enough how to measure the voltages simply using one of the connectors on the back - maybe the FDD port you can do it?
It's all about summoning up the enthusiasm as well as accepting the fact you can spend a whole day on these things and get exactly nowhere, or you might even fix it and when you take it back off the shelf it's gone bad again....
VeryVon
Mentions of failing parts / issues here. YMMV.
jsilcox
New member
Had this same problem. I replace all the capacitors, the two diodes and a couple power transistors on the analog board, but the optocoupler was the biggest culprit. Once I replace the optocoupler it booted, but still reboots randomly after anywhere from 1 to 5 minutes.
I am going to check all the resistors, since those are reported as drifting over time.
