Color Classic VGA mod with stock logic board - will it work?
KillerKong
Hi!
I was considering VGA modding my Color Classic, but then read this warning here: https://colourclassicfaq.com/general/vga.html
"PLEASE NOTE: if you perform a VGA modification to your Colour Classic's analogue board, you MUST use a logic board other than the stock Colour Classic logic board. The CC board will not put out a VGA signal and will be unable to drive the monitor, resulting in what will appear to you as a dead CC."
I don't see this warning on other resources. Is it false? Can a Color Classic stock logic board (256 kB VRAM) work with the VGA mod?
Thanks for any info.
zigzagjoe
Hi!
As far as I'm aware that warning is correct. The original logic board doesn't have enough VRAM to do VGA@256 color, it isn't designed to sense what monitor it's detected to, and probably is not able to generate an appropriate frequency for VGA.
GRudolf94
What @zigzagjoe said. If you trace the harness between analog and logic board, you'll see that two of the monitor ID pins on the CC board go nowhere, and one beeps to the main ASIC.
KillerKong
Reading this page it seems that you CAN in fact mod a Color Classic with a stock logic board to do 640 x 480, but to get color you need a 256 kB VRAM upgrade. Am I wrong in thinking this?
iJol
I've scored a CC with ThunderCachePro last year and it's modded to 640x480 with the stock logic board, so yes it's possible.
KillerKong
Thanks for confirming!
Did you do the "Option 2: 84V - HiRes Mod" as mentioned on this page? https://powercc.org/640x480/
The one that involves changing the following components:
Component NameOld ValueNew Value
CL93.3µF 160V2.2µF 160V
CL103.3µF 160V1.8µF 160V
DL21?18V Zener BZX85C18
DL22?Remove
RP64.52K Ω resistor5.11K Ω resistor
RP815K Ω resistor, 5W33K Ω resistor, 5W
RF14236K Ω resistor216K Ω precision resistor 1%
RP2322K Ω resistor, 3W33K Ω resistor, 3W
RL5433 Ω resistor, 1W15 Ω resistor, 1W
RP61-7,5K 3W resistor
RL6247 Ω resistor, 1W100 Ω resistor, 1W
RL7033K Ω resistor, 1/8W22K Ω resistor, 1/8W
J104Jumper10 Ω 2W resistor
iJol
I have to check that, I haven't done the mod myself, it was modded when I bought it used and never opened it up since them. :D
Arbee
All of the color compact 68k machines respect the monitor sense pins. Apple themselves took advantage of the flexibility, since the Mac TV internally is a Color Classic with 640x480 from the factory.
