Classic AB reverse e engineering
ironborn65
Hi pals,
I have a Classic AB badly damaged due to the usual caps electrolytes; there are too many bodge wires to make and pads are badly lifted or even missing. I could remove al the parts, clean it thorough-fully and re solder back in everything, but it's so soaked with acid and that it will probably not even work. .
I have googled around, but I did not find a reversed PCB, I'm missing it or it was never done?
thanks
ironborn65
KiCad schema file added to the repository.
The project is not completed, anyone can follow up on it, my resources are now limited
