Some time ago I bought a Macintosh Classic. I checked online and people said to recap a non-functional logic/analogue board, so I cleaned and recapped the analogue and logic boards fully.
"Okay" I thought, "maybe I should turn it on." So I did. what I got was what I'd describe as a flickering pulsating checkerboard pattern with weird sounds coming from the speakers. I checked online and a post here said to replace the Optocoupler and some diodes on the analogue board.
So I did.
It stabilized the Image and got rid of the flickering and speaker problems, but that still left me with a checkerboard pattern. Did some more snooping around here and a lot of posts said that the checkerboard pattern tends to be a RAM issue, due to the memory mapped display these old Macs have.
So I bought a multi-meter and went to town on the ram chips. All of them seemed to be fine when doing a continuity test and checking for short circuits.
I also have thoroughly cleaned both boards with alcohol after removing the original caps and re-seated the ROM chip.
I've tried searching extensively across the web for info on this topic but most of the info I could find was relating to the Classic II.
I wanted to know what kind of issues a checkerboard pattern could indicate, just so that I can eliminate some procedures from the list. Any help would be appreciated, even if its just a link to an old service manual or a PDF of a more up to equivalent of the dead mac scrolls.
So I did.
