Choosing a Starup Disk on OS 7.1
habibrobert
Hello,
I seem to be having some trouble trying to select a start up disk using OS 7.1. I go to control panel, then starup disk. I see my three partitions there, but when I try to select the partition I want nothing happens. The hard disk is only highlighted and when I close the box and reopen it, I see that all three partitions are highlighted instead of just the one I wanted. I tried just selecting the Hard drive and then immediately restarted the computer without closing the starupdisk application but it still does not boot up to the disk that I want. What am I doing incorrectly?
Thanks
habibrobert
I tried using system 1.1 a3 but it did not detect my other partitions. So I decided to try 1.1 b and that one did detect my partitions, but when I selected a parting to choose from and restart the computer, it would default to using the main OS that I initially installed (OS 7.1).
uniserver
if you boot 7.6 or 8.0, 8.1 then it will not ignore your choice from the start up.
what are the other OSes on the hd?
habibrobert
I'm just using 7.1 and 7.0.1. I don't have system 7.6 or anything else to boot up with. I mainly just want to test that this thing works. once I know that it works I'll go out and find 7.6. So is this why it's not working? Cause I'm using an OS that does not support this kind of a feature?
So then what you are saying is if I boot up with 7.6 and choose a different disk to start up with (say OS 7.1), the computer will not ignore my choice and restart and boot OS 7.1?
uniserver
i just noticed with these huge SCSI sca hard drives that i have, when i make like 8 partitions and install different os'es on some partitions.
if i am toggling back and forth between 8.1 - 7.6 and (I think) 7.5.5, from start up disk, all is fine. when i boot up 7.1 it seemed like, no matter what os i choose it would always boot up to 7.1 basically ignoring my selection, however if i booted up 7.6 from my zip drive and set the start up disk that way, it would work fine and reboot from the HD and run those oses again.
habibrobert
Thats very interesting. I was starting to wondering if I had installed OS 7.1 incorrectly, or had a corrupt disk or something. But if you are having the same issues then it makes sense that the SCSI HDD is causing.
