Aztec LC PSU still ticking after recap
CompuNurd
I just recapped an Aztec PSU from a Mac LC, and when I go to turn it on, it just ticks. The solder connections look fine, is there something I am missing?
The voltages I am getting are: ~4.5 from the blue wire, ~1.25 from the yellow wire, and ~.60 from the orange wire.
360alaska
Are you plugging it into the board when your testing it? It must be connected to the logic board?
techknight
umm put it on diode check. Red lead on all the rails, 1 by 1, black lead to black.
What are you readings?
CompuNurd
What's it supposed to read? My meter has the diode and 2Kohm functions together. When I measure, the reading is ~.200 then rises up to ~1.700, and keeps going.
techknight
Then there are no shorts on the rails.
So, as long as the power supply is connected to a load, it should run. You may need to change the opto-coupler.
CompuNurd
I have tested the optocoupler and it seems to be fine (unless I tested it wrong?).
I guess it never hurts to try. The model is CNX82A, Mouser and Digikey do not stock it, but I found some on eBay.
CompuNurd
The optocoupler seemed to fix it, but there was a humming, presumably from the transformer, and a lifted pad. I don't trust it, so I will be scrapping it.
techknight
humming is normal, as long as its soft/subtle, thats the analogous sound of the power supply regulating itself.
CompuNurd
It was audible from several feet away. If you want it, I'll send it to you for the cost of shipping, shoot me a PM. Better someone make use of it than it being trashed.
