Astarte DVDirector Pro - pre-DVDSP
CJ_Miller
For a few months I have avoided using my Macs or buying anything for them. But I am getting over depression, wanting to mess around, and the wife joined a band. Things are starting to get a bit creative here again.
So on a whim I started searching for Astarte video stuff. They invented Toast. I have CD-Copy which is amazingly useful, only secure-rip tool existent for OS 9 so far as I know. And I heard that Astarte tools formed the basis of the original DVD Studio Pro application. It seemed like for OS 9 video work their stuff would be great.
Just minutes of looking and I found a computer lease liquidator outfit offering Astarte's DVDirector Pro, we agreed to $30 for it postpaid and now it is here. It includes two PCI cards, the infamous Wired4DVD MPEG decoder card, and a MediaPress MPEG encoder card. There are installers and licenses for M-Pack (MPEG encoder), A-Pack (AC3 audio encoder), the main DVDirector application (basically does menus, like DVDSP), Toast DVD 3.7.1. Also apps for managing the PCI cards, and utilities for MUX, subtitles, etc. And they included all of the required cables and adaptors I could need, including an iMate USB>ADB adaptor which is worth $30 itself.
So now I am trying this stuff out. First thing I am wanting to do is rip some VHS tapes I want to archive so I can see them - I don't usually have a television set up. To my surprise, I am having difficulty with the Wired4DVD card: it plays VOB files on my hard drive but DVDs in the drive show up as torn and pixelated noise. I might have better luck using an older DVDR drive with this setup, I know OS 9 could be picky about CD drivers. Or maybe some alternate extensions might work with what I have. I have had hair-pulling experiences ripping tape before. My $10 Aurora Fuse card yielded nice picture, but the audio always went further out of sync for the length of the recording, it wasn't a linear offset. It was too much work to fix files longer than a few minutes. And I scored a cheap Matrox RTMac encoder which I heard good things about, but couldn't get it to work with my version of Premiere. Hopefully the MediaPress will be what I needed.
I am also intrigued by the possibilities of offloading MPEG 1/2 en/de-coding from Max/MSP/Nato. But since I set up my Mac with new OS 9 partition I forgot to authorize Max on here so I can't test it now.
CJ_Miller
MediaPress encoding seems to be working! I don't have enough cables, I tried a few junkers I found and set them aside. This means I can't use my TBC yet. I tested a minute of tape and the results were quite nice indeed. One problem is that the MediaPress encoding is supposed to allow preview through "a compatible MPEG decoder card", which is what the Wired4DVD card is supposed to be for... But I can't enable it, the selections for previewing are ghosted out. Meanwhile I patched a loopback so that I can monitor the VCR output while it streams to my MDD. After encoding my first tape of 44 minutes (GearVision Logic Audio Basics & Techniques Vol.1) I will check out the resulting file for sync issues.
Oh, and I wonder whether or not this stuff will do progressive scan... interlaced might be ok for ripping old tapes, but I since I don't typically use TVs I don't need interlace.
CJ_Miller
I did start doing some encoding with the included MediaPress card. Mixed results so far. After about 30 minutes encoding stops with an error about my system being too slow... I seriously doubt that, it wasn't even straining.
As for the encode quality? When I played back on the television it looked great. But then trying to watch on my computers was not as good. There was a bit of warping at the top of the screen, as if the top inch or so was shifted slightly to the right. Also there were weird grainy artifacts when viewing up close. The first problem I am hoping may be solved by recording through my TBC rack and using better cables. And the second problem I am hoping I can remedy by improving upon the default encoding settings.
Why does the encoding stop? I will need to look into that.
At this rate it might be a while before I try actually authoring DVDs with this setup, but it does have potential.
