As I've repaired the SE/30 I've started looking at my ASANTE MacCon+ TK/TP (Rev B) card. I can't get this going. As I'm no expert on MacOS etc. I'm struggling both with get the drivers on a diskette but also installing.
I found an diskette image (High Density) which is version 5.1.2 but it doesn't matter how I install it, I can't get card running (I see different evidence of drivers/applications being installed).
The latest diskette with drivers I've found is version 5.6.1 but these images are in ".hqx" format and I've yet to find a method to extract them and create a diskette under Windows.
Of course, I don't know if the board is faulty or the card that is connected to the mainboard but at least there is activity when I connect it to a switch (green LED blinks).
I've tried several OSes so that isn't the problem at least.
So, any advice on how to expand and write .hqx images in Windows onto a HD diskette? If so, where do I download the correct software?
I've attached a picture of the MacCon+ TK/TP card connected to my switch.
TIA!
TIA!
