geerlingguy
I've been trying to get my PowerBook 3400c to connect to a netatalk 3.x-based AppleTalk server over TCP.
I have Ethernet connected to my switch, and I can get an IP address using DHCP. When I try to connect to the netatalk AFP share in Chooser, I get the error message:
Do I have to run netatalk 2.x to work with 8.6 on the 3400c? Or is there some other TCP or AppleTalk option I might be missing?
I tried installing AppleShare Client 3.8.8 on my 8.6 install, and that led to this "error of type 12". Before, on the default AppleShare Client version, I would get the error "The User Authentication Method required by this server can't be found," which is why I upgraded (see this compatibility table in the netatalk docs).The application "Chooser" has unexpectedly quit, because an error of type 12 occurred.
You should save your work in other open applications and restart the computer.
