Apple STB Recap Guide
jajan547
Hey everyone I made a recap guide for the STB. This guide is for the STB3 (not the much rarer STB1) but I also decided to make a teardown guide on fixit in case some of you are a little uncomfortable trying to see how to disassemble this device. I also wanted to clear up a common myth or two about this device and it's that the internal expansion bay bracket is fused to the board, this is untrue it comes apart and the right angle adapter also isn't soldered it comes right out. Anyways for the few that have one of these I hope it helps.
  • Apple STB Recap Guide.pdf
3lectr1cPPC
Absolutely if you need me to confirm what caps are said values just ask.
Found a couple discrepancies.
The list states that it has 1x 100uf 10v. From looking at the board, I see 2x 100uf 6.3v caps, and an additional one the Nichicon caps that is labelled on the side instead of the top, so I can't see it. Am I right to guess that you missed the 100uf 6.3v caps when writing the list, and that the one I can't read the values on is the single 100uf 10v cap referenced?
jajan547
So sorry about that yes the 100uF 10V is the unlabelled Capacitor at C199 and there are two more caps that are 100uF but at 6.3V both of these are located at C59 and C60. I've updated the list below, thank you for that catch I suppose I overlooked it.
  • STB3 Recap Guide.pdf
jajan547
No problem, thanks for clarifying!
100uF 10V is especially bad (the unlabeled) it's right next to an important chip (U47) and even if your board looks clean replace it ASAP! Also I reported my first post so that the PDF can be updated properly.
3lectr1cPPC
Maybe this is just a placebo, but I feel like it's always those yellow-label Nichicon caps that leak the worst.
jajan547
Yeah very, very bad I've seen it across multiple machines that use these. They bulge from the bottom and leak too. Anyways if anyones chip is too far gone (which I doubt but in 8-12 years I'd imagine its possible) the chip in question next to this evil capacitor is a BT BT8069BKPJ 44-Pin PLCC. They can be purchased still HERE
3lectr1cPPC
I found a couple more of what I believe are errors. One is that you originally had C199 (100uf 10v) noted down as a 47uf 16v cap, and didn't remove it after you added the correct value to your list, which means there are 11 total 47uf 16v caps on the board, not 12.
Secondly, you listed 16 10uf 16v caps, I counted 17 from the image.
With that in mind, here is what I THINK is a 100% correct labeled reference photo. Let me know if you see any mistakes here, I want to make sure it's 100% accurate before I put it up on the site.
And thanks again for letting me use the image!
jajan547
Looks great to me I’ll double check but think it’s 100%
