Apple IIGS Remote Boot Issues
Ive gotten my IIGS to successfully connect to my AppleShare Server and boot to the point of where it says cannot load GS.OS. So I Boot the AppleShare 3.5 disk, and go into control panels and click AppleShare and then the system hangs..
Any Ideas
Well I solved the issue.. Had to set the CPU Speed to Normal in the IIGS Control Panel to be able to mount AppleShare Volumes.. On a positive note, I can mount the linintosh box with it so I can make disk images of all the good software, and most software I can leave on the Quadras Hard Drive.. Its like having a hard drive without a hard drive
