bigmessowires
I've got my new AirTalk device hooked up to my Mac Plus, and I'm running the LocalTalk-enabled build of Mini vMac, and it's working! Very exciting to see this old machine networking over WiFi. But I'm having some problems I could use some help with:
- When I connect to an AppleShare volume, the option to connect as guest is grayed out. When I started file sharing on the other Mac, there was never an option to enable guest connections, only the network identity and start/stop file sharing. What have I missed? Both machines are running identical System 7.1 setups. Do guest connections require leaving the owner name blank? Now that I've set it, the control panel software tells me I'm not allowed to change it back to blank.
- AppleShare works between the two computers, but it's unusably slow. To open the icon for an AppleShare volume served by the MacBook Air and opened by the Mac Plus, which contained 9 items, it took almost two minutes. To open a small README text file it took five minutes. To unmount an AppleShare (dragging it to the trash) took about 2 minutes. I don't think this is due to the low bandwidth of LocalTalk. Looking at the AirTalk's activity LEDs for UDP and LT, while I'm trying to open a remote file, there are 1-3 seconds of inactivity between each brief blink of LED activity. It's like the device is spending most of its time waiting for something rather than communicating as fast as it can. Shouldn't I expect to see those activity LEDs blinking more or less constantly?
Any idea what's wrong? The FAQ mentions that latency over WiFi is higher compared to “real” LocalTalk and that this noticeably affects things like how quickly folder windows populate. But two minutes to open a window unfortunately isn't really usable. It seems weirdly variable. Opening a window can take several minutes, but in a few instances it opened in about 10 seconds. The progress bar for file copies often doesn't move smoothly - sometimes it goes quickly for a moment, then pauses for a long time. All the equipment is in the same room as my WiFi router, so I don't think this is a signal strength issue. I've not noticed any of the error LEDs lighting on the AirTalk board either.
EDIT: It might be coincidence, but things did seem somewhat better when using Mini vMac (in "all out" speed mode) to access the MacPlus disk, and worse when using the Plus to access the Mini vMac disk.
