Okay, got my Outbound 125. It has the internal floppy drive but the drive doesn't work. The drive has a belt internally so I'm not sure if it's slipping or if the motor is just messed up. Might be electrolytic caps in the floppy drive too. I was hoping the floppy was a generic PC floppy drive as I have read but, of course, it's not.
The floppy drive, indeed, connects to a small daughterboard that then plugs into the motherboard. Here's a pic of the 26 pin connector that goes from the floppy drive to the daughterboard:
Here's the daughterboard to motherboard connection via a 30 pin connector:
As you can see, the floppy drive has a weird connector that will be impossible to find unless someone has an extra Outbound floppy drive that works.
Here is the hard drive I bought that has 44 pins PLUS the four power pins (if I recall correctly) versus the motherboard that has a lower density 44 pin connector. Is this a standard cable or is this proprietary to the Outbound also?
Anyway, on another note, I did find a web page that had pictures of the Installation Manual for the Outbound 125 in my travels but I don't remeber where I found it so I put the images in a PDF file. Here's a link:
http://vintagecomputer.ca/download/outbound/Outbound-125-Installation-Manual.pdf
Note: this is really bad quality and there are missing pages but it's better than nothing. If someone knows of a good scan, let me know. I will scan the "User Guide" and "SCSI Adapter and Emulator" manuals that I got with my Outbound soon.
