Ah, that's a good idea! I just tried that with Audacity. I do happen to have LC II and III ROM images. I found the LC III's sampled startup sound using that trick (8-bit unsigned, mono, 22254 Hz), but I'm not so sure about the LC II -- it's only a 512 KB ROM, so is it possible that one is still synthesized? I did find a little horn honk sound, but that sound is also in the LC III. I guess I could find out for sure by disassembling the LC II's ROM. Either way, the LC III should work, and I should be able to get a good idea of where the sound starts in the ROM from Audacity.
Apple's ROM maps for the LC II are interesting:
They have ORIGBOOTBEEP, ORIGBOOTBEEP6, and ORIGERRORBEEP1-4 which are located at the exact same offsets as they are in the IIci. Then there is also BOOTBEEP, BOOTBEEP6, and ERRORBEEP1-4 which are located way farther on in the ROM. It's almost like they left some of the II series code in there alone...interesting...did you try an LC II ROM in the IIci? I suppose I could do that too since it's not any bigger...
The LC III has all of the beep related labels that are in the LC II, as well as some other stuff like DOBEEP, BEEPERLOOP, BEEPMIXERPATCHRETURN, and BEEPMIXERDONE. I'd say those would be a good place for me to start. It's possible that they might have something to do with the sampled startup sound.
I don't think it matters that much if I look at an 040 instead of an 030, so I could take a look at those too if the LC III doesn't get me anywhere.
