AFP, NTFS and SFM
porter
I'm updating my binhex and unbinhex tools to work on windows with Services For Macintosh AFP shares.
Resource forks are held as a stream called "AFP_Resource" and the various other information including the finder info is in "AFP_AfpInfo".
Doing the binhex is not problem because when I read the AFP_AfpInfo my safe guess is the type and creator are at offsets 16 and 20.
But to do the unbinxhex all I know is
(a) it has to be 60 bytes long
( B) it starts with "AFP"
© it has the type and creator at offsets 16 and 20
Other than that I don't know anything else about the contents of AFP_AfpInfo, can any one else shed any light?
Charlieman
I'm puzzled, mate -- are you talking about a Windows binhex tool, because AppleShare client/server should handle it for you on a Mac. Are you trying to work with binhex files between NTFS and FAT in Windows?
porter
I have a windows 2000 box with an SFM AFP share.
I wanted to do the unbinhex on the windows 2000 box, eg with no macs involved. Eg it's "unbinhex.exe".
So I have access to the NTFS share, and can read and write the AFP_Resource and AFP_AfpInfo but I can't get the AFP_ApfInfo contents correct. The macs complain about the resources even though the resource stream itself is correct.
porter
Okay this seems to solve it....
Code for Windows to create a file with Macintosh Type and Creator....
Code:
OSErr FSpCreate(FSSpec *f,long c,long t,long s)
char name[256];
char info[256];
BYTE data[60];
HANDLE h;
DWORD dw=60;
DWORD err=0;
memcpy(name,f->name+1,f->name[0]);
name[f->name[0]]=0;
h=CreateFile(name,GENERIC_WRITE,0,NULL,
		CREATE_NEW,0,INVALID_HANDLE_VALUE);
if (h==INVALID_HANDLE_VALUE) return GetLastError();
CloseHandle(h);
strcpy(info,name);
strcat(info,":AFP_AfpInfo");
h=CreateFile(info,GENERIC_WRITE,0,NULL,
		CREATE_ALWAYS,0,INVALID_HANDLE_VALUE);
	dw=GetLastError();
	DeleteFile(name);
	return dw;
memset(data,0,sizeof(data));
memcpy(data,"AFP",3);
memcpy(data+0x10,&t,4);
memcpy(data+0x14,&c,4);
data[6]=1;
data[7]=0;
data[0xF]=0x80;
data[0x18]=1;
if (!WriteFile(h,data,sizeof(data),&dw,NULL))
	err=GetLastError();
CloseHandle(h);
if (err)
	DeleteFile(name);
return err;
