9600 AV Options
istar1018
So I have access to a couple of PM 9600/200s, and I think I'd really like to use one of them to replace my current 8500 setup, as I'm really feeling a slot limitation. I can move my PCI cards, G3 upgrade & SCSI-IDE adaptor over in a pinch but...
The kicker is, the 8500 is a really nice AV machine, and the 9600 isn't really (at least in its stock configuration). There's no DAV port internally, and thus no composite / s-video jacks. Is there some way I can replicate this functionality on the 9600 through a PCI card? I'm planning on using an AM III for audio, but what about analog video capture?
Can anyone recommend an analog video capture card (with component & s-video jacks)? Bonus points if you know where I can get one. Cheaply. Or Freely. Extra bonus points if it can do output, too. Adobe Premiere compatibility is really my only critical limitation.
Bunsen
Admin-Witchfinder-General
PCI VideoVision Studio - although the full set takes up two or three slots, from memory.
Aurora FUSE
ATI Xclaim (and others?) w/ optional external TV tuner
Iomega BUZ(Z?) external converter, connects with a fast SCSI card for storage
Unknown_K
Videovision PCI is 1 card and you will need a good SCSI card, Telecast is the Videovision card plus the SP card.
I recommend the Media 100 early PCI cards, but you need a dongle for the software.
Bunsen
The nice thing about the ATI cards is that they also support displays - both VGA and composite/S-Video
