clh333
Greetings all,
In addition to SE Mac variants and a Quadra 650 I have a G3 beige desktop machine that I know little about: It has the 300MHz CPU, 760 MB memory, ATI video card, CDR, ATAPI ZIP drive and a 9+ GB HD. I believe the "personality" card is the "wings" variant; it has RCA and S-Video in and out; more than just audio capture. The Ethernet port is attached to a Cisco Linksys and through a wireless router to a networked Dell 1720dn printer. A 17 inch CTX monitor is running at 75 MHz, displaying 24-bit-depth at 832x624.
I have upgraded from OS 8 to OS 9.2.2, partitioning the HD as I did so, and upgraded the memory to the limit, but that's about all I have done, mainly because I don't know much about the hardware that is on the machine or what can be done with it. Some of the icons on the back are familiar, many are not, and there seem to be a lot of "if this then not that" inter-relations to the hardware config.
I'd like to add a FireWire PCI card but don't know if just ANY PCI firewire card will work. I have 2 MB video RAM but I read that can be upgraded to 6 MB. There is a CDR but I'd like to upgrade to a CDRW or DVD RW but again I read that not all CDRWs are compatible and of those, not all are bootable. And DVD RWs seem to need the "bordeaux" personality card. The networked printer is masquerading as a Laser Writer 8; seems to work but maybe there's a better option. The ATAPI ZIP drive is fussy about the disks it is asked to read and sometimes will refuse to recognize a disk until it has been "blessed" by another SCSI ZIP. The HD is getting full; I think I read that OS 9 can only handle a 10 GB drive but I also have read that larger drives can be used. Maybe with partitions?
I have a Mac Secrets book but a lot of what I need to know is specific to this machine and I'd welcome a reference to more particular documentation. Thanks for your suggestions.
-CH-
-CH-
