THX, trag.
Forgot to mention: all testing done on a
Radius 81/110 Mac Clone under
System 7.6.1 at this point.
MAXPower 2.0.3 Installer seems to b the ticket, I've now got a
Radius 81/110/G3/???/512 w/HPV up and running. *****
There is definitely something funky going on with the Drivers.
Gauge 1.0.2 installed by default in the MAXpowr Folder reports Proc Speed at 220MHz, but
TattleTech 2.8.1 reports it at 329.99MHz, neither of which jibes with the info spec'd by BG when he listed this batch of cards. Love 'em, thx, comrade! [
] ]'> That's probably due to specs changing and being listed differently for the three different clocks available in this series.
I don't know what's going on with the PDS Passthru, behavior appears to change depending upon whether or not the HPV Card is present and whether it's the first boot upon its installation or not. I need to try this with two or three monitors hooked up at the same time. I can't tell what's happening on the first boot when the monitor is running off the inactive Cable/Card. Curiouser and curiouser . . .
I'll need to try a later version of the MAXpowr drivers when I have some time. The next set of tests will be done in the current config with
TechTool added into the mix.
The
HPV->MezzanineLevelHack™ will be a bit neater and cleaner in this configuration than it would have been using the Sonnet Card and Cable. With the HPV Card mounted above and perpendicular to the NuBus Slots, all three NuBus Slots are available for the ersatz
System 100.
NuPower G3 v1.0.3 Installer didn't work in the Radius 81/110.
NUpowr G3 control 1.2 (Control Panel) thinks it "cannot be used with this Macintosh."
