equill
In the last month-or-so I have acquired three 68040 accelerator cards for use in a IIci PDS (cache) slot, and other Macs through an appropriate adapter: DayStar Turbo040, MicroMac Carrera040 and Mobius Speedster. I installed the DayStar card and QuadControl CP in my second IIci (with OS 7.6.1), replacing a DayStar PowerCache 50MHz. Off went the Turbo 040, and has never looked back. That's the way all CPU upgrades should be, no?
Tell that to the fairies. The Carrera arrived with one 22µF 6V capacitor (the kind that trag likens to 'little fuel tanks') loose in the bag, one ditto connected by one leg only to the card, a third properly in place, and the fourth completely missing. The solder pads showed no sign that there had ever been a cap there. From the dirt adhering to the MicroMac-branded cooling-fan's blades I gauged that the card had been in use for some time. With as many as three ineffectual caps? I replaced those three defective/missing caps with 22µF 25V tantalums. Then the Carrera went into my third IIci, with Carrera040 CP and Startup Carrera Extension (under OS 7.6.1). TattleTech 2.84 and MicroMac's Speedometer saw the CPU as '68030 25MHz', remarkably like the native CPU, rather than the expected 68040 40MHz. No loading order changes for the CP and extension let the system 'see' the new CPU, whether the startup volume was the internal SCSI 0 or an external SCSI 6.
So, out with the Carrera and in with the Mobius. The main card of both MicroMac and Mobius upgrades is, as nearly as may be, identical physically and (presumably) electrically, but the Mobius card did have all four 22µF caps in place as tantalum electrolytics. Only the 128kB cache cards differed significantly, in apparent design and in appearance, between the two accelerators. The same CP and extension as for the Carrera have been reported to serve for the Mobius. However, the Mobius gave the same result as the MicroMac: the CPU again showed as 68030 25MHz.
Part way through the battle of wills I replaced the IIci's Asanté 10Base-T NIC with an AsantéFAST 10/100Base-T card, to speed up transfers of software from the other two IIci Macs for troubleshooting. To complete that upgrade I installed OT 1.1.2 over the existing 1.1.1. Damme, if after restart, what does TattleTech show for the CPU but 68040 40MHz. Speedometer confirmed this. I still don't know whether the attached 128kB cache card is active, but one victory per skirmish is not to be sneezed at. What possible connection might there be between a CPU and a NIC that could wreak such a result?
Next step is to pick up jaw and re-install the MicroMac to see whether such a nearly identical card shows the same behaviour.
de
de
