LazarusNine
Just curious whether or not 64MB SIMMS are recognised on the 550 logic board or if 36MB (4 + 32) truly is the limit. Thanks!
I never tested memory in a 550; don't have one.yea i think it was trag... Trag was also the same guy that got 260 megs of ram to work in a quadra 605 if i remember correctly.
Trag, out of curiosity, is there a specific type of 72-pin 128MB SIMM that seems to work better than others in the 475?I never tested memory in a 550; don't have one.
260 MB in the 605/475 was with a 72 pin SIMM doubler and there was no closing the lid. A single 128 MB SIMM is more practical.
Could you drop 4 of those in a 650? Or is that where you would also need to add the ROM slot and use a dougg3 rom, bbraun style?right now i have 2 of these in my OC'd 6100, 256 megs of ram... sickness...
