olePigeon
So I'm attempting to build a custom Hyperdrive style upgrade for a 512k using a Supermac SCSI upgrade. Found this in one of the machines we're going to sell, so I'm trying to pimp it out before I put it up on eBay. The upgrade is a tiny daughtercard with a Macintosh Plus ROM and SCSI controller. It sits where the 512k's ROMs used to be and runs a long SCSI ribbon cable to the battery compartment, providing an external SCSI BUS connector.
As you can see, the SCSI ribbon is really long, and I have a SCSI crimp-on IDC header that I can add to anywhere on the ribbon cable.
So what I'd like to do is add an internal SCSI drive. With the SCSI2SD, it's so small I can mount it pretty much anywhere. In fact, I already have an idea of where I want to mount it, utilizing the existing screws that already mount the floppy drive. You can see one of the screws from the left side, it's identical on the right side (two screws hold the floppy in place.) Should be really easy. Gonna make a custom adapter on the 3D printer, just screw it in along with the floppy like so:
So mounting it and getting the ribbon cable is a snap. My only problem is the power to the SCSI2SD. How am I going to do that? Does anyone have any ideas? Is there a simple solution? I'd love to get this working. A 512k with a Hyperdrive style internal SSD would be awesome!
I remember reading somewhere that there could be a BUS powered SCSI2SD? Does that exist already? That'd solve my power problem.
