Yes. Here is my current situation:So, wait, you're actually sticking a pin in the eject hole to "manually eject"?
Oh, well there is that problem! Haha, thanks Unity!It will not eject the 800k drive. The 128k original ROMS dont know how to trigger the drive to do so.
And I did try it with both the A9M0106 and M0131 drives.But my external is an 800k drive, and it ejects? Sounds strange that 'Apple 3.5" External' (A9M0106) can eject but 'Macintosh 800k' (M0131) can not?
So I put in the system disk and then tried the "Eject Disk" option under the "file" menu. The icon of the disk looked like it was ejected (i.e., the shadow-ed outline of a disk) for about 3 seconds but then reloaded without the drive doing anything. This happens both with the original disk and a copy of the system disk I made.Honestly I wonder if something is borked with your disk controller. Can you swap disks at all? (IE, does soft eject EVER work?) Again, correct me if I'm wrong here, but on a Mac you should be able to drag the SYSTEM DISK to trash to eject it and put in a program disk; doing so creates a sort of "phantom" alias to the ejected system disk to basically remind you that the system will ask for it back later. If this wasn't possible a single drive Mac would essentially be useless.
That is a great question -- I will test it. I know that the Plus under System 6.0.8 ejects disks out of the external 800k drives, no problem. I will report back tomorrow!Yeah, so there's definitely something wrong. I seem to recall from another thread that you have a Plus, do the drives behave properly on that? (If you disconnect any SCSI hard drive a Plus should behave essentially identically to a 128k if you boot it with your System 2.0 floppies, does it eject the disks before rebooting?)
Ah HA! I tried booting off the same system disk from the same drive, but attached to my Mac Plus. It did the same thing -- no ejection of the disk, and auto-restart.Yeah, so there's definitely something wrong. I seem to recall from another thread that you have a Plus, do the drives behave properly on that? (If you disconnect any SCSI hard drive a Plus should behave essentially identically to a 128k if you boot it with your System 2.0 floppies, does it eject the disks before rebooting?)
