So. I have had the machine back now for over a month.
Scope creep lol (Somewhat Expensively) Some of that was my fault because, yeah tinkering. I have learned lesson.
Spec As before : 128Mb ram, Bluescsi V2 with 16GB SD card, Various System Builds 7.01/7.5.5/8.1, Caymac 8mb ROM with BMOW compressed homemade rom image (7.5.5)
Current Spec:
Logic/Analog board recapped as per falen5
Dimmo 030 recap (more on this later.)
Pico PSU adapter as per dekunukem - 160w Pico PSU/ Barel Connector.
New Wiring Loom and Neckboard (as per Zigzzag Joe)
PISCSI - external SCSI (plan to use as video out to Monitor)
Replacement Screen - burn in on my unit.
Floppy drive cog replaced and unit regreased/reassembled.
Noctua NF-A6x25 FLX - theres a handy 4 pin fan header on the Pico adapter.
Cosmetics:
SE30 rear case
SE 30 Appropriate drive caddy
My own twattery:
Umm yeah I broke the DiiMo Accelerator.
My bad. so it went its holidays (again ffs!) back over the Atlantic to ZigZagJoe for some fettling.
I was trying to do the "Enable 50Mhz 68882 Mod" because apparently Micromac only ran them at 25 Mhz.
I have also found later revision C 68030 and 50Mhzz 68882, but according to the guru of such things ZZJ, these may have been re-marked (pain, but they both go at 50 so... meh.).
Why ? Well the original Chips I had on the card were a B revision 030 ad a B rev 33mhz 68882, I'm hoping the later revision chips, regardless of mask/re-marking, are a bit leaner on power.
So, um yeah I broke a few tracks and yeah.... no lets not mention that.
Anyway I have everything back now and it works so that's it.
