kataetheweirdo
New member
It seems like you just need to include atomic.h in appleramdac.cpp. If possible, make sure you include the whole build log.
The upstream native build has two display windows. You have to move the second one out of the way to see the checkerboard and cursor in the first display window. You can remove the second display window by removing, "Sixty6Video"
from machinetnt.cpp. Later commits from my fork should fix that.
Actually, the system beep issue with the floppy goes away if you have--fdd_wr_prot=1
so that the system knows not to attempt writing to the floppy.
dbdma.cpp:273 FATL| ABORT: curio_scsi: non-DWORD read from a DMA channel not supported
error.It's not something I'd do casually on a public forum without a significant review to make sure there was no unintentionally captured personal data.If possible, make sure you include the whole build log.
That's great! Weird to see Mac OS 8.1 booting up in a sort-of mostly monochrome System 7! (But I understand it's kinda 7.6?).The actual issue with JS was that the alpha channel ended up being 0, and the JS side respected that, hence it being all black. I forced the alpha channel to be full opacity, and https://infinitemac.org/run?disk=Mac+OS+8.1+Disk+Tools+(PPC)&machine=Power+Macintosh+7500 boots to the Finder now (I also made the floppy images be read-only).
I think it might even be 7.5.* if I remember?(But I understand it's kinda 7.6?).
Disk Tools PPC
This remarkable Disk Copy image was included with the Mac OS 8.1 install CD, to allow a user to make her own minimal bootable rescue disk. It can read, write, format and repair HFS+ volumes.
Lacking the Appearace Manager and Finder 8, it looks and feels more like System 7. On closer inspection, I found that it actually is System 7! The contents of the resource fork reveal that it is based on System 7.5.5.
Tried BeOS with pm8600. 7.5.3 and 7.5.5 CD hang during boot with HD60_512_BeOS.hda as the first HD. Using HD50_512_BeOS_Mac_Tools.hda as the first HD, I can launch BeOS Launcher but it hangs at the BeOS logo while waiting for Mesh DMA (even though the CD and HDs are attached to Curio). We might be stuck there until we have Mesh (internal) SCSI working. Is BeOS able to boot from external SCSI? If yes, then we just need to make Mesh work without SCSI devices.If anyone wants to play along at home.
Attached is a 7.6.1 minimum install with the support utilities from BeOS version 4.5 and 5.0.3. Note for some reason I seem to be using versions that say 4.5 on my actual computer, even though it boots 5.0.3. I can't remember why as it is years since I set it up.
Actual BeOS pre-installed image is available here :
Make sure you don't go crazy with the RAM - BeOS doesn't boot if you have too much. 64 is plenty (it works with more, but there is a limit I can't remember).
Out of the list of machines on infinitemac, I think the 9500 is probably the best machine to go for. Does anyone know what video card is being emulated in the 9500? Any card that has an appropriate Mac driver in ROM should work slowly, but only a small number of cards supports acceleration. Both cards that came with the 9500 (ATi Mach64 based thing and the ixMicro TT) are "fully" supported.
hdiutil attach HD60_512_BeOS.dmg -nomount
hdiutil attach HD50_512_BeOS_Mac_Tools.dmg
-nomount
on the BeOS HD because that one has no Mac partitions that are viewable in the Finder.--cpu=
option. Upstream doesn't have 8500/8600/9500/9600 yet but did recently include the --cpu option. Actually, upstream does have 7300 which defaults to 604e.hdiutil create -size 1g -layout "UNIVERSAL HD" -fs HFS -volname "MacOSForBe761" ~/Disks/MacOSForBe761
xxd -p -r <<< '0004 0000 0040 0017 0001 0000 0078 0024 ffff 0000 00b0 0015 0701 0000 00e8 0022 f8ff' | \
dd if=/dev/stdin \
of=/Users/joevt/Disks/MacOSForBe761.dmg \
oseek=0x10 bs=1 conv=notrunc
Usually booting 7.5.5 doesn't reach the Finder unless you're holding the shift key during boot to disable extensions. It appears to be the same for Infinite Mac. Those DMA aborts are removed from my fork. Whatever is causing my fork to hang might be related to whatever is doing the non-DWORD read or it might be something else. It would be nice to be able to use Conflict Catcher to find the conflicting extensions, but it doesn't let you indicate pass/fail of a test during extension load time even though Conflict Catcher can appear during extension load time which is unfortunate since it can't handle conflicts that cause the Finder to be unreachable? Maybe I'm using it wrong.Booting with a SCSI disk image (e.g. http://infinitemac.org/1996/System ...e&saved_hd=false&machine=Power+Macintosh+7500) also works, but it eventually fails when it gets to the Finder with a
error.
It is yes, the old manual mentions doing a test install to a zip disk, without specifying which bus it needs to be on.Is BeOS able to boot from external SCSI? If yes, then we just need to make Mesh work without SCSI devices.
Yes! Completely forgot the 7500 came with a 601 - I don't own one and was just assuming everyone would have a 604 shoved in there. You have to remember most of my PowerSurge machines were bought as just logic boards and I have a "processor card drawer" I grab arbitrary Processors from "Today I will be a 133MHz 604"...I think the default CPU for pm7500 is MPC601. Doesn't BeOS require 603 or later?
I wondered this and left it after testing on infinitemac - no problem to add, just meant I could generate it in Basilisk II quickly.MacOSForBe761 is a partition image. It needs to be a disk image (include partition map with drivers) to work with native DPPC. Infinite Mac has code to automatically add the missing parts. We'll want to add code inside DPPC to do that later.
Not a modern Mac user personally sorry.For people using macOS,
I just use template images of an array of sizes. Zipped they take up no space, and I take a copy to make a new one.People have suggested different apps to handle/create disk images but I prefer the command line.
Surely Dingus PPC must support supervisor mode, because the PPC emulator must run in Supervisor mode (because the 68K emulator must be able to run in PPC Supervisor mode, because 32-bit clean code and System 7 needs 68K supervisor mode)? I'll reply with lots of shocked emojis if I turn out to be wrong !What does dingusppc think about software going into supervisor mode?
I thought they might have done something dodgy to break out. Was wondering if it might cause an issue.Surely Dingus PPC must support supervisor mode, because the PPC emulator must run in Supervisor mode (because the 68K emulator must be able to run in PPC Supervisor mode, because 32-bit clean code and System 7 needs 68K supervisor mode)? I'll reply with lots of shocked emojis if I turn out to be wrong !
Doesn't every emulator need to support supervisor mode since every OS needs supervisor mode? PPC exceptions are handled by supervisor mode exception handlers. For example, Mac OS 9 running on a PowerPC CPU goes into supervisor mode during an illegal instruction exception to emulate MPC601 instructions or to emulate instructions that have an alignment exception such as accessing a 64 bit floating point value whereWhat does dingusppc think about software going into supervisor mode?
address & 3
is not 0.But I'm getting the impression it wasn't a valid pondering.
As I said before, you'll need to add this line to appleramdac.cpp if you want it to compile:So https://github.com/dingusdev/dingusppc compiles (but obviously doesn't have all of joevt's changes in it), but https://github.com/joevt/dingusppc doesn't.
It fails while building appleramdac.cpp
#include <atomic.h>
Thank you. I did that and it just throws an error on that instead.As I said before, you'll need to add this line to appleramdac.cpp if you want it to compile:
#include <atomic.h>
#include <atomic>
instead.#include <atomic>
Yeah, I found that on stack overflow and just tried it -Which version of gcc do you have installed? You'll want to make sure you have at least GCC 4.4.
Also, try#include <atomic>
instead.
<userprompt>: /mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/build$ make dingusppc
Consolidate compiler generated dependencies of target speex
[ 1%] Built target speex
Consolidate compiler generated dependencies of target cubeb
[ 10%] Built target cubeb
Consolidate compiler generated dependencies of target devices
[ 11%] Building CXX object devices/CMakeFiles/devices.dir/video/appleramdac.cpp.o
In file included from /mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/devices/ioctrl/macio.h:55,
from /mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/devices/video/appleramdac.h:28,
from /mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/devices/video/appleramdac.cpp:25:
/mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/devices/common/dbdma.h:153:27: error: field ‘ch_stat’ has incomplete type ‘std::atomic<short unsigned int>’
153 | std::atomic<uint16_t> ch_stat = 0;
In file included from /usr/include/c++/11/bits/shared_ptr_atomic.h:33,
from /usr/include/c++/11/memory:78,
from /mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/devices/common/ata/idechannel.h:32,
from /mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/devices/ioctrl/macio.h:54,
/usr/include/c++/11/bits/atomic_base.h:162:12: note: declaration of ‘struct std::atomic<short unsigned int>’
162 | struct atomic;
/mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/devices/common/dbdma.h:155:27: error: field ‘queue_len’ has incomplete type ‘std::atomic<unsigned int>’
155 | std::atomic<uint32_t> queue_len = 0;
/usr/include/c++/11/bits/atomic_base.h:162:12: note: declaration of ‘struct std::atomic<unsigned int>’
/mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/devices/common/dbdma.h:156:27: error: field ‘queue_data’ has incomplete type ‘std::atomic<unsigned char*>’
156 | std::atomic<uint8_t*> queue_data = 0;
/usr/include/c++/11/bits/atomic_base.h:162:12: note: declaration of ‘struct std::atomic<unsigned char*>’
/mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/devices/common/dbdma.h:157:27: error: field ‘res_count’ has incomplete type ‘std::atomic<unsigned int>’
157 | std::atomic<uint32_t> res_count = 0;
/mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/devices/common/dbdma.h:162:27: error: field ‘cmd_in_progress’ has incomplete type ‘std::atomic<bool>’
162 | std::atomic<bool> cmd_in_progress = false;
/usr/include/c++/11/bits/atomic_base.h:162:12: note: declaration of ‘struct std::atomic<bool>’
/mnt/60fd23a1-36b2-4d79-89b5-53dea5502477/store/projects/Macintosh Stuff/Emulation/dingusppc/dingusppc/devices/common/dbdma.h:163:27: error: field ‘cur_cmd’ has incomplete type ‘std::atomic<unsigned char>’
163 | std::atomic<uint8_t> cur_cmd;
/usr/include/c++/11/bits/atomic_base.h:162:12: note: declaration of ‘struct std::atomic<unsigned char>’
make[3]: *** [devices/CMakeFiles/devices.dir/build.make:930: devices/CMakeFiles/devices.dir/video/appleramdac.cpp.o] Error 1
make[2]: *** [CMakeFiles/Makefile2:340: devices/CMakeFiles/devices.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:242: CMakeFiles/dingusppc.dir/rule] Error 2
make: *** [Makefile:169: dingusppc] Error 2
It reverts to the original error.
