131.738: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
131.751: [ 75576035]: Driver - Hub driver - (1) dead port dead port disabled 2
131.751: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
131.754: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
131.771: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
131.787: [ 75576035]: Driver - Hub Driver - Device found, calling USBHubAddDevice. Port 2
131.804: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
131.837: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
131.852: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
131.885: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
131.922: [ 0]: USL - findEndpointAddr -1
131.922: [ 0]: USL - Stalling pipe 75576704
131.922: [ 75576035]: Driver - Hub Driver Error - Could not read 8 bytes of device descriptor before set address -6911
131.954: [ 0]: USL - findEndpointAddr -1
131.954: [ 0]: USL - Stalling pipe 75576704
131.954: [ 75576035]: Driver - Hub Driver Error - Could not read 8 bytes of device descriptor before set address -6911
131.988: [ 0]: USL - findEndpointAddr -1
131.988: [ 0]: USL - Stalling pipe 75576704
131.988: [ 75576035]: Driver - Hub Driver Error - Could not read 8 bytes of device descriptor before set address -6911
131.993: [ 0]: USL - findEndpointAddr -1
131.993: [ 0]: USL - Stalling pipe 75576704
131.993: [ 75576035]: Driver - Hub Driver Error - Could not read 8 bytes of device descriptor before set address -6911
132.026: [ 0]: USL - findEndpointAddr -1
132.026: [ 0]: USL - Stalling pipe 75576704
132.026: [ 75576035]: Driver - Hub driver - no more reties in device zero -6911
132.026: [ 75576035]: Driver - Hub Driver - Set address failed, giving more time 36
132.070: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
132.102: [ 0]: USL - findEndpointAddr -1
132.102: [ 0]: USL - Stalling pipe 75576704
132.103: [ 0]: USL - UIMEDDelete did not get lock on UIM 0
132.103: [ 75576035]: Driver - Hub Driver Error - Setting the device address -6911
132.136: [ 75576035]: Driver - Hub Driver - Set address failed, increasing time 3
132.136: [ 75576035]: Driver - Hub driver - disabling dead port 1 1
132.137: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
132.138: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
132.170: [ 75576035]: Driver - Hub driver - (1) dead port dead port disabled 1
132.170: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
132.200: [ 75576035]: Driver - Hub Driver - Device found, calling USBHubAddDevice. Port 1
133.151: [ 0]: USL hubs - timing out add 1000
133.151: [ 123456789]: UIM - UIMControlTransfer: endpoint not found. -6987
133.151: [ 123456789]: UIM - OHCIUIMTKillRemainingTransaction- Endpoint not found -6987
133.151: [ 0]: USL - calling ctl packet handler because of error -6987
133.151: [ 0]: USL - errorCallBack -1
133.151: [ 0]: USL - findEndpointAddr -1
133.151: [ 0]: USL - UIMClearEndPointStall did not get lock on UIM 0
133.151: [ 123456789]: UIM - UIMEndpointDelete: Could not find endpoint -6987
133.151: [ 0]: USL - UIMEDDelete did not get lock on UIM 0
133.183: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.225: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.255: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.286: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.316: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.326: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.357: [ 75576035]: Driver - Config pipe zero failed -6998
133.357: [ 75576035]: Driver - Hub Driver - Set address failed, giving more time 69
133.357: [ 75576832]: USL - Invalid ref passed to USL 0
133.357: [ 75576832]: Driver - **** USBDelay gives kUSBUnknownDeviceErr, retyring with hub ref -6998
133.357: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.433: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.449: [ 0]: Driver - SimulateRootHubInt- queuing SF for non int case 0
133.449: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.463: [ 75576035]: Driver - Hub Driver - Set address failed, increasing time 4
133.463: [ 75576035]: Driver - Hub driver - disabling dead port 1 2
133.463: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.482: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.496: [ 75576035]: Driver - Hub driver - (1) dead port dead port disabled 2
133.496: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.499: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.513: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.531: [ 75576035]: Driver - Hub Driver - Device found, calling USBHubAddDevice. Port 2
133.543: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.575: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.592: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.625: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.658: [ 0]: USL - findEndpointAddr -1
133.658: [ 0]: USL - Stalling pipe 75576960
133.658: [ 75576035]: Driver - Hub Driver Error - Could not read 8 bytes of device descriptor before set address -6911
133.698: [ 0]: USL - findEndpointAddr -1
133.698: [ 0]: USL - Stalling pipe 75576960
133.698: [ 75576035]: Driver - Hub Driver Error - Could not read 8 bytes of device descriptor before set address -6911
133.735: [ 0]: USL - findEndpointAddr -1
133.735: [ 0]: USL - Stalling pipe 75576960
133.735: [ 75576035]: Driver - Hub Driver Error - Could not read 8 bytes of device descriptor before set address -6911
133.740: [ 0]: USL - findEndpointAddr -1
133.740: [ 0]: USL - Stalling pipe 75576960
133.740: [ 75576035]: Driver - Hub Driver Error - Could not read 8 bytes of device descriptor before set address -6911
133.776: [ 0]: USL - findEndpointAddr -1
133.776: [ 0]: USL - Stalling pipe 75576960
133.777: [ 75576035]: Driver - Hub driver - no more reties in device zero -6911
133.777: [ 75576035]: Driver - Hub Driver - Set address failed, giving more time 69
133.847: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.878: [ 0]: USL - findEndpointAddr -1
133.878: [ 0]: USL - Stalling pipe 75576960
133.879: [ 0]: USL - UIMEDDelete did not get lock on UIM 0
133.880: [ 75576035]: Driver - Hub Driver Error - Setting the device address -6911
133.910: [ 75576035]: Driver - Hub Driver - Set address failed, increasing time 4
133.910: [ 75576035]: Driver - Hub driver - disabling dead port 1 1
133.910: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.940: [ 75576035]: Driver - Hub driver - (1) dead port dead port disabled 1
133.940: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
133.942: [ 0]: USL - processDelayQ delayQueueChanged, breaking 0
