DarthNvader
Question: How powerful of a graphics card will work in a beige Power Macintosh G3?
Got it!!! Also had to remove the kernel cache from the /System/Library/Caches folder. You did it @joevt, thanks for all your hard work!
forums.macrumors.com
Confirmed to work on the Beige G3 with G4 upgrades( Rev. A and Rev. C ROMs )
Likely we can get it working on any PCI Mac with a G4 upgrade that can run OS X( Likely not the 7200's or the L2 Cache slot upgrades as we don't have a driver to make the G4 work under OS X )!
