Nepnep
Hello all, and happy new year! I’ve decided to start messing with my Beige G3, which is quite an upgraded model with a sonnet 500mhz G4, ATi Rage 128 with a DVD decoder, and running MacOS 10.4 Tiger thanks to XPostFacto.
But that’s decides the point. I’ve had a spare Multiple Scan 14” display laying around that has the old DB-15 Macintosh Video connector, and I was going to see if I can use it as a second monitor alongside my main monitor on the PCI graphics card. The only problem is that it doesn’t seem to display an image? I know the monitor works, and have heard of people using a setup like this, but has anyone else tried it under an unsupported OS and had any success?
Edit: turns out it does work, you just can’t hot plug the old DB-15 monitors
