(Verbatim) VST for Macintosh UltraTek/66 IDE RAID (PCI) | SSD bootable Solution
jessenator
Having already given up on the SIL3112 scenario for my PowerTower, I've been on the lookout for another drive solution. I saw this card come up on eBay, and noticed the verbiage "For Macintosh" and took a gamble that it would play nice with Old World ROM Macs and become a (stable) drive controller for my IDE-less PowerTower.
After a not-so-long, but frustrating bout, I actually got the controller to boot and work stably with a *64 GB SSD, which was attached to the SATA controller in the link/post above, only in this case I'm using a double-wire/contact IDE cable, and a SATA-IDE bridge. It's already withstood several MacBench 4.0 "All Disk Tests" runs with exceptional performance (which I thought odd given that it's not a particularly fast IDE rating, but my knowledge is patchy there).
(this is just the testing setup... I'll clean it all up once I'm done, and yes, that's red duct tape, because I don't want to hot glue it down)
My first attempts were stymied:  Option 1) CF-IDE adapter (using a known-good, booting CF card that works in my PM4400/StarMax plugged into the on-board IDE connector) and Option 2) same SATA-IDE bridge but a slightly newer, and larger 240 GB (all I had spare...) drive, which of course registered as a 128 GB drive. Neither of these solutions proved fruitful.
  • Option 1 just gave me hard freezes before the Mac OS screen (is gray screen a "post"?) no matter the configuration on the adapter (like I say, works in a native Mac's IDE board connector)/ I got pretty disheartened by this, as the CF card Just Works™ in my other machine.
  • Option 2 would mostly work, but would give me very strange errors, and I'm thinking the physical drive size is the culprit here (Apple menu freezing open, CHK and Type 10 Finder errors, but changing from boot to boot). IRC member
The working solution is basically Option 2 with a smaller sized SSD (still connected through the same SATA-IDE bridge). Also, I should point out that while not exhaustively tested, a double-contact IDE cable is almost certainly required. When I tried a standard IDE cable with Option 2 (just to check the cables I had on hand) I would get hard post screen freezes (experienced only with Option 1 up to this point), instead of the errors happening post-Finder. The double-contact cable at least would boot the machine. But like I say, the smaller SSD works! As mentioned (probably?) in the thread I started before (linked top), the system would hard freeze when doing anything remotely disk-intensive: running a disk testing program, or, very specifically, installing Windows 98 onto a PC Setup image file for a PC Compatibility Card. A member on IRC suggested a smaller disk size, and *that solution works!
Thought I'd share that with the Forum that, though these may not be that common anymore, maybe for a while they'll provide a less-than-arm-and-a-leg prices for a Sonnet card. Your mileage may vary. For other, more pragmatic individuals, something like SCSI2SD, RASCSI, MacSD, etc. might be more turnkey. I was exploring other options for my PowerPC machines which lacked on-board IDE support and this one worked :D
Sorry for the potato quality, but here's a look at the results from MacBench 4.0 (my system at the bottom)
trag
Do you know what firmware is on the card?  The 2.2.4 version will give you OSX compatibility without hindering your Classic compatibility.
I don't remember for certain, but I don't think the Ultra/66 ever added large drive support beyond 128 GB.
It's not really worth the effort now days, but the card is based off the hardware of the Promise UltraTek/66 and the conversion is not too difficult, although one of the resistors that needs to be moved is under the Flash chip, so the Flash chip must be desoldered in order to perform the modification.   I can't remember if it also needs a larger flash chip installed.   It's been like 20 years...
Back in the day, one could find the Promise card in deals like 10 for $50...
When the card was still available new, it was offered in a bundle with SoftRAID for a while.  That was a good deal.
jessenator
Yeah, I do see "Promise" on the card, but I have no clue how to read the firmware. Above my pay grade, sadly :lol:  Though I'm not terribly bothered by not having X compatibility, TBH. I'm just glad it works in System 7. I haven't tested anything lower than 7.6, but on my PPCs (in my possession) I kind of irrationally hate 7.5.x—it's not bad on my Quadras though.
Too bad most of those Mac-ready cards are probably ash at this point. But yeah, from what little I know plus what you've explained, probably not worth the effort to convert the PC ones, perhaps even less than the SIL3112 SATA cards, despite my own negative experience with them.
