Snial
I wonder if the issues you've been having with adapting JM20330 mSATA - IDE is related to the issues I had, as discussed here:So far it looks like this:
ASIN Product Prucut tyoe Chipset Manufacturer Chipset Name Works? B0026OYEEQ Startech IDE2CF IDE / CF Adapter No Chipset -- YES B07QJXCDBR Swissbit CF Card 2 GB fixed CF Card ? ? YES B00ELC8GFO DELOCK 62495 IDE / mSATA Adapter Marvell 88SA8052-NNC2 NO Harddsik setup does not recognize B00EOJNGC2 StarTech IDE2SAT2 IDE / SATA Adapter Marvell 88SA8052-NNC2 NO chime, black screen B09GPGFLWB MO3C IDE / SATA Adapter ? B77AS0041 NO Harddsik setup does not recognize B0041LCTGW SATA2IDE44VAO IDE / SATA Adapter Jmicron JM20330 NO Harddsik setup does not recognize B07476J7NK EVB-002-3 IDE / SATA Adapter Jmicron JM20330 NO chine, welcome, system error 3 B083LXPF91 N-1801 IDE / mSATA Adapter Jmicron JM20330 NO chine, welcome, system error 3. Without system extension: startup, everthing okay. But not stable sometimes starts up with errors 1, 10 and 11
So, now I will test the N-1801 with 7.6 and 8.6.
The funny thing: although the JM20330 is used by multiple manufacturers and they only seem to adopt the application note schematic, it has different outcomes.....
Mac Mini G4, mSATA-to-IDE adapters and Master/Slave
When putting a mSATA in a 44-pin IDE adapter into a Mac Mini G4, is it possible to set whether it is a master or slave on these adapters. My CF-IDE adapters have a jumper for master. According to Wikipedia, the 4 extra pins are for power. IDE uses 40-pins (including one mechanical one). When I...
