The experts would need to chime in, but I would think that any paired drives having identical seek times and RPM that are fast enough to swamp the I/O buses of the systems would be a good solution.Certainly some of the numbers will be HDD dependent, but we should be able to get at least some notion of how the different storage mediums compare. A lot of people have the SCSI2SD V5, and while that is SD-card dependent, it gives a someone more consistent test drive.![]()
As far as a 40MHz Quadra 630 goes, no way! You can't have a $1,200 40MHz Quadra announced the very same day they ended production of the $4,700 Quadra 840AV with plans of pushing lobotomized offspring into the retail channel at Performa price points.
Talk about getting IIvEXED! The 840AV was produced for just one single year. Shift two resistors and install a 40MHz full 040 into a Performa to hack yourself an 840AV rival? UNTHINKABLE!!!! :lol:
edit: with TV Tuner! ;D
