Outbound Laptop repair/reverse engineering
I bought a Microsoft InPort Mouse C3K5K5COMB and found that it wasn’t a simple pull-up design — it actually uses IC control.
So I wired the mechanical encoder and microswitches directly to the DIN 8-pin connector.
I also added 4.7 nF ceramic capacitors between each of the four terminals of the mechanical encoder and GND to suppress contact bounce.
After 40 years, an external mouse is finally back on my Outbound.
Thank you.
Here’s another piece of information to share.
One possible cause of an Outbound failing to power on is a faulty reed switch in the power module.
The system is designed so that pressing the four keys activates the reed switch, which turns the power on.
The reed switch is still available today.
The power module is the aluminum case on the plug side of the AC adapter.
Ah, yes, that ID is for the serial mouse - you want the bus mouse version. Mine was marked C3K5K59937. Glad you got it working!
What did you do for the cable? All the serial cables I came across have a thick cable not suited for use as a mouse, initially I spliced a serial cable to the mouse but later made a custom plug casing out of ABS.
I used a D-sub 9-pin mouse cable and replaced it with a DIN 8-pin plug (soldering it was quite a challenge).
The mouse that originally came with my Outbound was discarded because it was mistakenly thought to be faulty when the keyboard battery voltage dropped (it had been lent out during a business trip).
Since then, for about 40 years, I haven’t been able to find a Microsoft Bus Mouse. I also tried modifying several Bus Mice, but none of those attempts worked.
Until now, I couldn’t confirm whether the external mouse port was functioning properly.
But now I can confirm that everything on my Outbound Docking System is working correctly.
I’m truly grateful.
I’m truly grateful.
Glad you were able to get it working! It looks good - factory, even. What did you do for the plug?
Also, I'm jealous of your working docking setup. I don't have the docking bits for mine.
I found a beige DIN plug on AliExpress.
Running the Mac from a RAM disk is surprisingly smooth, and I’ve been using it in a fairly practical way by connecting SheepShaver over Ethernet with an Asante EN/SC adapter.
I think I'm just going to throw together an adapter to use an optical mouse for the VCF display. Probably more reliable than the ball mouse at least.
Just to correct my previous note:
Using 4.7 nF ceramic capacitors for debouncing does not allow proper tracking when the mouse is moved quickly.
Around 1.0 nF seems to be optimal.
Took a second to probe the presumed video port on the outbound. As expected, it's very much not VGA and if you plugged a VGA monitor in it's going to short the -16v line to ground. Don't do that!
Bought one back in the 90s that someone had done that to. It killed a diode in the power supply. Machine would not boot up until I replaced that diode. Happily, Perfit was still operating at the time and they were willing to give me the part number for the dead diode.
First, the driver does read CHS values from the disk: I tested 93.75 MB working (CHS 800 6 40) which all values are different from the original drive. I am sure there is a limit somewhere but I'm in no hurry to find it :)
IIRC, various old Connor 2.5" IDE drives worked including 20, 40, 60 and I think 80 MB.
You may have already discovered this, but you can switch between internal floppy and internal hard drive, by installing the desired hardware and then running the EEPROM updater (forget what Outbound called it) and it will configure the machine for whichever was installed.
Was the GAL on the floppy controller locked?
I would if my mouse worked 🥲
At this point I can't tell if it's just the mouse itself not working or if there's a problem with the computer. I think when I was trying to run things with just the keyboard alone it would freeze up when opening apps. It also doesn't prompt to initialize the RAM disk which I thought it was supposed to do.
Are you using the correct key sequence when you boot the Outbound? There's a different sequence for keyboard - docked, and keyboard - not docked, and if you use the docked when they keyboard is detached it usually won't work. Vice versa and one gets strange behavior, IIRC.
Especially as they supposedly support up to 16MB in the ramdisk.
Can confirm from experience that 16 MB is supported. However, even while shut down, a 16 MB RAM disk will deplete the main battery in less than 24 hours. So if one wants the Silicon disk to be persistent, one needs to leave the Outbound plugged in.
I've toyed with the idea of building some SIMMs out of SRAM chips to lower the power requirements. Not sure how well that would work out by the time I add logic to deinterleave the addressing.
Booting from disks (not read only) is a bit corrupt-y still but it will read disks written in other machines and write disks that other machines can read, in 1.4MB Mac, 800KB Mac, 720KB PC, and 1.4MB PC.
Everything I post is IIRC, because it was 2 decades ago, so sorry for repeating IIRC, over and over again.
IIRC, there's a floppy corruption issue if you leave the floppy inserted when you shut down. I think htere were some details, but I can't remember them. I probably have a written note somewhere. Where? Good question.
Hmmm. Has @cheesestraws ever been in touch with you? He was trying to get a docking card working a few years ago and needed the pinout for the docking cable.
Mouse that came with my Outbound Model 125. From the discussion here should I conclude that not all Bus Mice will work?
I also pulled the GAL from the External floppy and dumped it. It was a GAL16V8A 25QJ in PLCC form factor.
Thank you for that. It's been 30 years since I programmed a PLD. Does the .zip file contain what I'd need to use my TL866II+ to program a GAL16VD-15 with that logic? Sorry for being obtuse.
Also, do you have the SCSI adapter? Would you like to read the GAL from a SCSI adapter?
I only have the external floppy. But yes, i dumped the GAL and eprom from it along with the earlier hdd code, it is posted in here somewhere. It was not locked.
Any hdd old enough to reply with an ATA-1 identify matching what it expects could work, or a zuluide set to spoof that as I did. It would also be possible to just patch that check out.
If you want to DIY a mouse as I did yes it must use mechanical encoders, not optical encoders. I posted the FCC ID of a suitable Microsoft inport mouse earlier in thread; outbound was buying those, putting a new cable on it, and slapping a new sticker on as seen in your picture.
@cheesestraws sent me home with a spare outbound drive, so I quickly recapped it and changed the belt. It seems the BP cap in these drives can be left alone, but the 16v 10uf and 22uf caps should be replaced. I do not know what the 10uf cap is used for, so it should be kept as an electrolytic cap. The 22uF caps are just bypass caps for motor/logic power, tantulums are fine to use as long as they are 10v rated or higher. Capacity can be increased according to whatever you've got to hand; I used 47uF. Same story for the 68uf electrolytic cap on the driver board, anything 10v rated of equal or greater capacity ought to be fine, I used a 100uF 10v.
To make the recapping and rebelting easier, you can remove the floppy carrier without messing up the alignment. carefully push the two rails which the disk "carrier" bracket ride in out of the way so it can be lifted clear. Lift the heads slightly and you can then carefully finagle out the carrier. Make sure to install the new belt before reinstalling the carrier.
With two working drives it allowed me to do a bit of A/B testing to determine if my (repaired) drive had the same quirks as the "new" one, and the answer was yes; in particular the behavior where it usually corrupts boot floppies unless they're set read only was identical along with the fairly slow write speed and occasional inability to read disks from other machines. It might be interesting to compare the internal eeproms for the internal floppy machines vs. the contents of the external floppy's eeprom. All 4 external drives I've seen appear to have the same eeprom markings suggesting identical contents; 3 had the Rev B board with bodges, one had a Rev A board with an additional bodge.
Hmm.... just popped some SE FDHD ROMs into my outbound, as @cheesestraws has lent me the SE docking card for reverse engineering. Behavior is odd. The startup beep is anemic (quiet). It will not complete boot with ZuluIDE, sticks on the kangaroo logo. However, floppy boot seems to work, and it no longer is corrupting disks...? That said, I just popped the Plus ROMs back in, and it too is not corrupting the test floppy if it is left read-write. No idea what's up with that.
Perhaps SE FDHD ROMs are no go. Those would have been released after the machine was released, after all, and wouldn't be surprised if they didn't want to get into the engineering effort to get the new ROMs working. I have some retrofit boards I can put the earlier ROM on...
IIRC the FDHD ROMs shouldn't be a problem. The only major change was the floppy driver, all the patched memory addresses should still point to the same places.
IDE appears to be enumerated then the system hangs at the Outbound logo with the FDHD rom. With the non FDHD rom it proceeds past and boots from the ZuluIDE, but I need to update the System file on my disk as it seems to not support SE. The chime was still anemic sounding though and seems to take a bit longer to get through the POST process as compared to the Plus ROMs.
