Overclock LC475/P475/Q605 without soldering or spicy-o-clock
No, because I‘m using SwitchRes to define profiles for automatic resolution switching for certain games.
I suppose then that I should do the resistor mod instead, since everthing works great at 40MHz
The resistor mod will only work for 33Mhz as far as i know.
Soft475 also changes the ram timings which might not be properly configured with only the resistor mod for 40MHz.
I recently picked up a couple of LC475 machines and tried out @Phipli's Control Strip Module – initially both topped out at 40MHz.
I upgraded one with a MC88916DW80 and it is now able to go faster. It's stable up to 45MHz, and crashes at 50MHz.
Configuration:
  • 68040FE25 (L88M mask) on a PGA adapter
  • MC88916DW80
  • 70ns internal RAM
  • 60ns RAM module
  • 80ns VRAM
Continuing my experiments with Soft475, I installed an 88916 onto my other LC475 logic board, intentionally picking one with a different/newer date code. Despite using the same L88M CPU as before, the results are a bit better: I can actually set 50MHz and it works. However, it is unstable. It runs for a few minutes, exhibiting graphical glitches (specifically font rendering, oddly) then crashes.
I will try adding more cooling to the CPU, and see if that helps.
Can confirm that resistor swapping an LC475 to get 40MHz does not work, in my experience - it needs the more elaborate solution!
I tried my original LC475 board again. I had previously reported this:
It would hard lock immediately every time 50MHz was selected.
With a fan pointed at the CPU, it now works and runs without issue.
So it seems that both my boards will do 50MHz.
Were you using the control strip? It's more stable than the Control Panel and tends to have fewer graphics glitches at the limit, but JDW keeps pushing everyone towards the Control Panel, I think just because it has more buttons.
More Buttons <> Better
Edit - I see in an older post that you are using the Control Strip. In which case it might be worth finding some faster VRAM.
See post #165 above :)
Time for a peltier cooler and 60MHz! (If you do, make sure you protect the board from the condensation).
There is also a resistor R13 that it might be worth tweaking the value of - it's on PClk and technically should be tuned for your frequency. While we have values for 20, 25, 33 and 40, sadly they can't be trivially extrapolated because there seems to be an inflection. I haven't experimented with R13 yet.
