The resistor mod will only work for 33Mhz as far as i know.No, because I‘m using SwitchRes to define profiles for automatic resolution switching for certain games.
I suppose then that I should do the resistor mod instead, since everthing works great at 40MHz
Soft475 also changes the ram timings which might not be properly configured with only the resistor mod for 40MHz.
