cozyMIDI - new app that plays std midi files (68k)
Mu0n
cozyMIDI:​
my brand new 68k mac application coded in C (and sweat). Plays standard MIDI files assuming you have an external module plugged on the modem port.
  • loads and plays type 0 (1 track) and type 1 (more than 1 track) standard MIDI files
  • keeps them in a pre-calculated form so the loop doesn't have to do real time divisions at the cost of slightly longer file opening delays
  • animations with small graphic zones using CopyBits and 32 pixel width to keep it lean different MIDI instrument out of the 128 regular general MIDI instruments
    Mac Garden link: https://macintoshgarden.org/apps/cozymidi
    Github link: https://github.com/Mu0n/1bitdreammachine/tree/main/cozyMIDI
    this is a project that continues in the path I took over the last 2 years about MIDI and vintage computers for several platforms. Here's a previous thread here where I got some great help. Thanks to all involved!
Thanks for taking this one to the finish line, @Mu0n ! Brings back memories of using DMCS, a Mac Plus and a Korg! That setup (I suspect due to DMCS) tended to bottom out with more than four voices though.
Will it also work with QT Midi if it's present?
Good question.
The only mac I have that could test this is this G3 with OS9.
My code attempts to reconfigure the serial port and send all data through it. I don't use the Apple MIDI driver, nor OMS nor QuickTime. I'm not knowledgeable in all eras past 7.5.5 in Macs...
Thanks - I’ll have to try it out with my Roland SC.
Does the program work with System 7.5 or OS 8?
these are the setups I've made it work with so far:
Plus: 6.0.8
SE/30: 6.0.8
SE/30: 7.1
Basilisk II (68040): 7.5.3, communicates to host win11 PC's midi module with hairyMIDI and com0com
Snow (iicx): 6.0.8, communicates to host win11 PC's midi module through python script that listens to a tcp port Snow sends to, and sends it back to USB to my midi module
Good question.
Sorry: preamble! Well done! Looks like you've done an amazing piece of work! I used to have an MT-32, which despite being pre-General MIDI I suppose is an obvious target if the patches are remapped. I also once had a Roland SC-D70, which I bought to go with my Tangerine iBook, but that's also sold. So, many congrats!
I started to have a look at your GitRepo. I tried to search for the term: "preProcessEvents" within the repo:MuOn/1bitdreammachine/cozyMIDI.
I can't figure out how to do that even after looking at the syntax help! Surely this is one of the most common use-cases? I can search for a term across the whole of GitHub or I can search for a file within the current repo or I can search for the project path within the repo as a whole and get the whole text - except GitHub, despite it's zillions of lines of code, can't tell that <cr> by itself could be a line ending and there's no option I can see to make it grasp such a simple concept.
e.g.
repo:Mu0n/1bitdreammachine path:/^cozyMIDI\// symbol: PreProcessEvents
Returns nothing (except here I had to add a space between ':' and 'P' because otherwise the 68KMLA site would turn it into :P <facepalm> ). I also tried omitting the symbol: bit and various other permutations.
Completely un-intuitive pile of tosh of a search system.
e.g.
Regarding the forum emoji problem, you can surround the text with [icode] and [ /icode] or [code] and [/code]:
repo:Mu0n/1bitdreammachine path:/^cozyMIDI\// symbol:PreProcessEvents
Code:
Regarding the GitHub search problem:
Maybe the repository hasn't been indexed yet? I cloned it and searched locally.
Code:
mkdir -p /Volumes/Work/Programming/1bitdreammachine
cd /Volumes/Work/Programming/1bitdreammachine
git clone https://github.com/Mu0n/1bitdreammachine.git Mu0n-1bitdreammachine
cd /Volumes/Work/Programming/1bitdreammachine/Mu0n-1bitdreammachine
#grep -r -i 'preprocessevents' .
bbfind 'preprocessevents' .
/Volumes/Work/Programming/1bitdreammachine/Mu0n-1bitdreammachine/cozyMIDI/muMIDIplayer.c:299: void preProcessEvents()
/Volumes/Work/Programming/1bitdreammachine/Mu0n-1bitdreammachine/cozyMIDI/muMIDIPlayer.h:40: void preProcessEvents(void); //count events per track, allocate array of midi event structs for them
/Volumes/Work/Programming/1bitdreammachine/Mu0n-1bitdreammachine/cozyMIDI/openmidfilemac.c:32: preProcessEvents();
grep doesn't produce good results because the source files have classic Mac OS carriage returns instead of Unix linefeeds so I used bbfind from BBEdit.app.
Maybe GitHub doesn't know the files are text because of the carriage returns?
Carriage returns break source control. A commit to change a single line may look like a commit that changes the entire file? That's why you should convert to linefeeds before committing to GitHub. Add a conversion step to the step where you transfer the files to the classic Mac OS file system. Add a reverse conversion step where you transfer the files back to the GitHub client file system. The conversion step also needs a file creator and file type setter to make the files work with the apps on classic Mac OS (the IDE, the resource editor, etc.)
I see that some repository directories have .finf and .rsrc folders. But some do not. These are SheepShaver/Basilisk II related? I guess the GitHub client was Windows or Linux? For modern macOS, one could create a script to apply the info in the .finf and .rsrc folder to the files.
The repository includes StuffIt files with copies of the source files. Extracting the StuffIt files on modern macOS will create files with the correct Finder info and resource forks. I guess that's better than using .finf and .rsrc folders but seems redundant.
The GitHub repository only include text files as separate files. All the resource files, project files, binary files are in the StuffIt files.
For resource files, I would add a MPW Rez/DeRez step. Have all the resources as .r files so they can be included in the repository. However, I don't think DeRez produces results that are deterministic? i.e. the resources of edited resource file might not always DeRez in the same order which would make source control difficult? Therefore, I would make an MPW script that produces sorted results for DeRez. For example, this output is not sorted:
Code:
derez -p -only xxx /Volumes/Work/Programming/1bitdreammachine/Mu0n-1bitdreammachine/cozyMIDI/releases/CozyMIDI.pr.rsrc 2>&1 | sed -e 's/.*Skipping //; /^[^'"'"'].*/d; /^$/d'
Code:
'vers' (128).
'icl4' (128).
'icl8' (128).
'ICN#' (128).
'FREF' (128).
'BNDL' (128).
'PICT' (129).
'PICT' (130).
'PICT' (131).
'PICT' (132).
'PICT' (133).
'PICT' (134).
'PICT' (141).
'PICT' (140).
'PICT' (150).
'PICT' (151).
'PICT' (152).
'MBAR' (128).
'MENU' (128).
'MENU' (129).
'MENU' (130).
'MENU' (131).
'WIND' (128, "CozyMIDI").
'DLOG' (128).
'DLOG' (129).
'DITL' (128).
'DITL' (129).
'STR ' (128).
'Mu0n' (0, "Owner resource").
But it could be sorted with the sort command. Then each resource could be DeRezed in the sorted order.
Having to install MPW might be a hassle. Rez and DeRez works on modern macOS but that's not helpful when your GitHub client is on Windows or Linux.
Plus: 6.0.8
SE/30: 6.0.8
SE/30: 7.1
I did some midi a long time ago between Parallels Desktop and Mac OS X.
https://forum.parallels.com/threads/can-parallels-direct-output-to-a-usb-device.103501/
I haven't tried recently.
I tried running it off of my Powermac 6500/275 and it does open, but the midi file opening+parsing process freezes the machine.
I've never targeted powerpc and/or 68k running on powerpc before with my code, so this is well above my paygrade to attenpt to fix.
Same with the quick "send middle C note" with my menu, locks the machine. It must be a significantly different serial chip by then.
I don't think the SCC has changed.
Are you using modem or printer port?
For printer port, you have these addresses: 0x1E4 0x1E8. Where did you get those values from?
Both modem and printer port are supposed to be accessed using SccRd and SccWr at 0x1D8 and 0x1DC. These are listed in LowMem.h
Then you use the offsets in Serial.h to access the registers:
Code:
enum {
  aData                         = 6,    /* channel A data in or out (historical) */
  aCtl                          = 2,    /* channel A control (historical) */
  bData                         = 4,    /* channel B data in or out (historical) */
  bCtl                          = 0     /* channel B control (historical) */
I believe SccRd and SccWr are 0xF3012000 on machines like the 6500 that use GrandCentral?
Code:
enum {
Wow, absolutely right again. I misread how these ports worked. I couldn't find the same information in Symantec C++ 6's LoMem.h and Serial.h exactly, except the base addresses of SccRd and SccWr, but a quick check in Inside Mac II-199 yields these same offsets.
I replaced my code with this when I set the serial speeds:
C:
void TweakClock(Boolean OutOrIn, Boolean wantA)
    Ptr addr;
    short controlOffset = 2;
    addr = *(Ptr*)(OutOrIn ? 0x1DC: 0x1D8); //out, otherwise in
    if(wantA == false) controlOffset = 0;
    addr[controlOffset] = 4; //WR0 = register pointer set to WR4
    asm{MOVE.B (SP),(SP)} //2.2 us delay
    addr[controlOffset]=0x84; //WR4 = x32, 1 stop bit, no parity
    addr[controlOffset] = 11; //WR0 = register pointer set to WR11
    addr[controlOffset]=0x28; //WR11 = Rx and Tx clock from TRxC pin (HSKi on Macs)
I don't know anything about 'GrandCentral', I'll have to read on that. If it turns out that I can Gestalt my way into checking if it's available without crashing a Mac Plus, I'll include it in. I suspect there will be stepping stones cascading checks before I get to the final destination... I dread it a bit.
Thank you for all your help, it's really appreciated.
I don't think doing Gestalt will be necessary unless you can find a difference between 68K and PPC SCC.
You can probably just assume there's an SCC if you can open the driver as you do. Check the SccRd and SccWr values to make sure they're not weird (null or inside RAM).
Mac I/O controllers with SCC in Power Macs:
  • Grand Central (connects SCC from Curio)
  • O'Hare
  • Heathrow
  • Paddington
  • KeyWest
  • KeyLargo
  • Pangea (contains KeyLargo)
  • K2 (contains KeyLargo)
  • Shasta (contains KeyLargo)
I don't know when or if Power Macs stopped including a serial port.
My Quad G5 doesn't boot classic Mac OS and doesn't have serial ports but does have an SCC in the Open Firmware device tree and the Mac OS X I/O Registry. The Mac I/O controller has compatible K2-Keylargo.
Power Mac 6500 uses OHare but it's at the same address as GrandCentral so I guess SccRd and SccWr is still 0xF3012000 on the Power Mac 6500?
That changed with the iMac, didn't it? Likewise, the blue & white PM G3, in 1998. Apple made a clean jump from the two serial ports to USB. But IIRC, the SCC was exposed via OF on all PPC Macs. I recall doing something on my G5 and finding that I could plug a serial adapter into USB and the SCC "just worked". However, with the B&W, I believe Apple switched to a Zilog SCC, which it used until switching to the southbridge architecture. But the OF interface stayed the same, so I presume they tried for backwards compatibility through the entire line.
I meant when Apple stopped including a way to use a 85C30 compatible SCC (Zilog, AMD, etc). With the iMac, B&W G3, and some G4s, you can connect an adapter (GeeThree Stealth Serial Port, Griffin gPort, Jamport, etc.) to the modem port on the motherboard that allows a connection to the SCC that exists in the New World Mac via a Mini Din 8 serial port.
For my Quad G5, there exists Q63 schematics. It shows SCCA and SCCB pins on the SHASTA but they are setup for I2S devices (modem codec for SCCA and SP/DIF for SCCB). A hardware/software mod would be required to change the pins for SCC usage.
