Yet another simasimac SE/30 giving me grief
mattsoft
Started working on an SE/30 that won't start-up normally. Here are the symptoms:
  • Simasimac-looking image on boot
  • Death chimes immediately at power on
  • Interrupt button does nothing
  • Reset button will re-play the death chimes but not reset the image
I've done the following:
  • Voltages tested at molex on logic board are good
  • Recapped the SMD caps and cleaned the board
  • No battery damage
  • Tested RAM in another machine good
  • Reseated and cleaned the video ROM and PALs
  • Without ROM SIMM, no death chimes but same image -- guessing the ROM SIMM is OK
  • CPU is not halted (F12), CPU clock (E1) is good, CPU /AS and /DS are active -- I think the CPU is good which is probably consistent with death chimes at startup
  • Did the continuity test matrix from the last 2 pages of the schematics (that was labor intensive) and found no bad traces
  • Tested the clock signals from the troubleshooting guide (pg. 38), all are good
  • Performed the ROM address-walk from the troubleshooting guide (pg. 46), and other than the guide being slightly incorrect, the address-walk tested good
My next step is to continue through the troubleshooting guide (pg. 47+) and check the waves from the video ROM and multiplexing ICs.
Any other obvious ideas to check? I don't want to just start pulling chips, so any suggestions I can test with a multi or oscilloscope would be welcome. Thanks!
I have seen the simasimac pattern for the NEC, Ti, and Mt VRAM chips, yours doesn't look like the typical simasima pattern.
It's good that you get a chime of any type, as it means you can most likely use a serial cable to read your error code:
A lot of times a full simasimac condition SE/30 won't load the ROM, like yours seems to be doing.
Seems like testing the Video ROM chip is a good place to start.
EDIT: The Simasimac Repair Guide recommends to test continuity between the PDS slot and ROM slot, and not the CPU directly, because it's easier to access, but if you have a broken trace in between the CPU and ROM, that won't always show up by checking only the PDS slot. I learned that one the hard way.
Ya, I'm going to check out the video ROM on the scope tomorrow. To connect the SE/30 to a modern PC/Mac via USB, I'll need to figure out all the cables and adapters to make it work. Does someone have handy-dandy links to those? :)
I was given this link back when I was building a cable for PC to SE/30:
But my SE/30 simasima wouldn't chime and therefore load the diagnostic ROM.
Did buy a Techstep later to confirm everything was functioning correctly; a 4-pin mini DIN for the SE/30 serial port is what's necessary if you decide to build one.
Cables arrived and with the use of the excellent Reconnaissance app (https://recon-68k.github.io/) I connected the SE/30's serial port to a 2019 Intel Mac's USB port and ran the suite of tests.
A bunch of memory errors and a bad SWIM. Everything else checked-out OK, including all things video.
I toned out bank A and everything was good. Checked the /RAS and /CAS and all data and address pins on the SIMM slots and everything was good. So I started swapping SIMMs again for the 12th time just in case and...
No more simasimac screen or death chimes! The screen is now just pure grey and nothing else. Even though the SIMMs I had installed worked on my IIsi, they were giving the SE/30 grief. But now it looks like the SWIM is not working. Was going to scope it and see if anything is amiss and maybe reflow the pins, and then...
I restarted the SE/30 a couple more times and the simasimac and death chimes are back. lol! Maybe a cracked solder joint somewhere and the board flex of pushing and scoping got it to work or something.
The RAM might not be making good contact. You can probably limp it along with tape or the 3D-printed braces, but the slots themselves may need to be replaced eventually.
ya, maybe. the SIMM sockets look good. every pin in bank A looks OK. I'm reflowing everything on this board just in case. lol
Glad to hear things are improving.
When you had just a gray screen with no floppy in the center, was the mouse still working?
Troubleshooting is a lot of false positives. :) The grey screen was an artifact from the video tests persisting after short reboots, so it was a red herring.
With good SIMMs installed, the Reconnaissance app (https://recon-68k.github.io/) says everything is good except for SWIM.
So I started probing SWIM:
  • Pins 11, 22, 30, and 44 are all +5v
  • Pin 25 /RESET is high
  • Pin 26 /FLCK is 15.7 MHz
  • Data pins 4, 5, 8, 9, 13, 14, 15, & 18 all have activity
  • Address pins 37, 40, 41, & 42 all have activity
  • Pin 43 /DEV has actitivity
  • Pin 3 /WRREQ is stuck low
  • Pin 24 /RDDATA is stuck low
  • Pin 2 /WRDATA is floating around 1v
  • Pin 33 /DAT1BYTE is stuck low
From what I can tell on the Internets, this means the SWIM is dead or not working properly. Guess it's time to look for a working SWIM chip. Ugh.
Just saw an interesting SE/30 diagnostics video, where he sockets the main chips on a working logic board, and then proceeds to remove the chips one at a time to demonstrate what happens. It was interesting to see that the SWIM chip does cause the simasima condition if it's removed, or not working properly.
He removes the SWIM chip around the 1:02:35 mark:
Wow, thanks! Ya, I'm pretty sure this is a bad SWIM. I'm getting simasimac and no chime (now that I know I have good RAM in there). Going to have to shelve this until I can find a battery bombed donor board with (maybe) a working SWIM or a free range SWIM that I can replace this with.
Ordered a new SWIM and in prep, removed the old one from the SE/30 board today. without the SWIM, the SE/30 does the same thing so either (a) the SWIM is a red herring (I hope not) or (b) the SWIM was not functioning correctly and removing it demonstrates consistent behavior. can't wait for the new one to arrive to try this out!
The screen you're showing in your first post, is not like any simasima pattern I've seen before. What brand are your VRAM chips?
MT brand.
At least I know the video RAM and subsystem is good thanks to the Recon app which runs tests against it. Well, assuming the Recon app is testing it thoroughly.
Anyway, I'll know within a couple weeks when the new SWIM arrives and I can tack it into place.
Update! New SWIM chip in...and...she posts!
Need to test floppy and SCSI next and clean up all the damn flux I used on the board. But there you have it, if you see the error in the original post, it could be a bad SWIM chip.
and we have boot! floppy drive works (int and ext) and SCSI works (int and ext).
now I've got an ADB issue. mouse only goes up and down and click registers. no horizontal. when the keyboard is unplugged.
with keyboard plugged in, I get nothing.
both ADB devices do work.
starting to troubleshoot that now...
