Rominator I on Mac 128K issues
I've built the ROMinator I from Kay Koba for my Mac 128K. The build went smoothly but when I started up my Macintosh, I heard both startup chimes, the bong and the Glass, at the same time. It went to the pirate icon and after pressing R I saw a Disk X icon. It was interesting that when I double clicked the mouse, it would force eject the floppy. Then I tested again booting from Floppy, but it would just do a few seconds of reading, not reaching the Welcome to Macintosh, and just ejecting the disk. It's a known good disk.
I went ahead to do the basic troubleshooting:
1. Checked for bad solder joints.
2. Re-soldered the cables to the CPU pin's 9, 45, 46, 47
3. Verified continuity for connections on the Rominator PCB to all socket pins.
4. Verified continuity/short circuit for the 2 Jumpers (COM to 512K). (They are clear with the 512K setting)
5. Took off Rominator and re-inserted the original roms, booted up, and machine behaves as expected.
I've reached out to Kay Koba and he recommended to replace the ROM sockets on the motherboard to ensure a better fit. I have not done that yet and would appreciate any guidance. I have not desoldered anything from the motherboard. Even when I tried to recap the motherboard, I was unable to safely desolder the capacitors. It sounds to me like a daunting task to desolder all those pins from the sockets and safely remove the old sockets from the motherboard without causing any damage.
Here are some photos showing the type of sockets I have found on my motherboard.
At first glance, I wouldn't suspect anything wrong with the ROMINATOR. What you described sounds more like an alignment problem with the floppy disk drive. Have you tested it before installing the ROMINATOR? You mentioned your machine is a Macintosh 128K—is the floppy drive the original 400K unit, or has it been upgraded to 800K? Oh, you mentioned that everything works as expected with the stock ROMs. That's odd. Those original sockets are indeed a frequent source of headaches, and replacing them is a delicate task.
Thank you for your input. It's the 400K drive. When I inserted the original roms, the floppy worked as expected, but when the rominator was inserted, the floppy did not boot and just ejected after reading a few tracks.
I've also had a set of 342-xxxx roms lying around, from a Mac Plus. I have inserted those and there is no problem. The floppy worked well with those roms as well.
I've built the ROMinator I from Kay Koba for my Mac 128K ...
I had worse trouble than you. Mine (not from Kay Koba & it was prebuilt) didn't do squat. I got a replacement "kit", assembled it myself and it worked fine. See https://68kmla.org/bb/threads/rominator-not-working.52136/ for all the testing I did.
The fact that your board does so much is good. I would verify continuity from the rom pins to the cpu pins and the ROM.E signal from (memory) BRU-1. I am thinking that one of the upper address pins is lacking. And double check that no rom pins are folded under when inserting into the socket. Check continuity on the jumpers, from the board header to the cpu pin. Not common, but could happen, that the crimp on the push-on-connector end is bad.
Since you got a "X", it didn't find/load the System 3.2 image/boot blocks that's in the upper rom area. Hence my thinking an upper address line is foobar.
However, there is still the chance the 74HCT02 chips is the culprit as it decodes some "stuff". I've got an order of 10 of 'em coming in soon from Aliexpress to try out on my original board. I'd be happy to send you a few if you're in the USA.
IIRC, holding the mouse button down during startup does eject the floppy. ICBW.
Thank you for all the insights and suggestions. I have tested a few more times without any results - I ended up reversing course and removed the rominator from this machine. I might try it on another Mac in the future if I have a chance. I ended up putting the original ROMs back in (64K rom). I felt also better about leaving this machine in the OG state because it is an early Macintosh 128k.
It would be really interesting if you could dump out your Rominator ROM to a file. You would need to dump out the full 1024KB from within the Mac OS.... or by using an EPROM programmer. I suspect the chips are OK. But the fact that you hear both chimes indicates the jump to address 421000 for the alternate chime (glass) is not working correctly. But then we can see what is on the ICs to make sure they look OK.
Did you try using compressed air to blow away some of the dust or dirt off the board, and especially in and around the sockets?
Hi all, I don't visit here often so I almost missed your conversation, but I noticed that this was a recent discussion so I decided to reply... In my latest blog post, I discuss why this kind of failure occurs and offer some technical comments on it. I also point out why the socket needs to be replaced. Please read it if you're interested.
The following may not be relevant to this thread, but please let me know if it's unnecessary...:
-And in another post, there was a patched base ROM that supports Mega Mac and Dove SCSI card, and it's taking me some time to check out the data on those, but they seem to do the initial boot-up model verification pass and are probably great. I think I'll check them out at the end of this month. @Builder68 kindly explained the circumstances to me.
Special thanks: @SuperSVGA , @Golden Potato, @Builder68
-Kero's Mac Mods still uses the real SST39SF040, but the DIP32 SST39SF040 is still only available as a refurbished part recycled in China. I intend to continue using the real SST39SF040 as before, but I imagine many people have bought fake chips from AliExpress. With an EPROM programmer, you can flash them by disabling the ID check. However, this prevents the use of BMOW's Flash tool.
BMOW's Flash tool 1.6 supports AMD29F040 and SST39SF040. Looking at the C language source code means that they can be rewritten relatively easily. Many of the SST39SF040 chips currently available are fakes. These chips have a surface that has been scraped and reprinted with a laser, making them look clean, but when examined with an EPROM programmer, they return the ID 0x37 86. The true identity of this ID 0x37 86 is very likely to be the "A29040" series manufactured by AMIC Technology (the semiconductor division of the former Mosel Vitelic), or a compatible (remarked) version thereof. Since the pin assignments, capacity (4Mbit = 512KB), and basic read operations are almost identical (compatible) for both the AMIC A29040 and SST39SF040, they will work once installed in a device. I've created a patching tool for the AMIC A29040, and I'll be releasing it soon. *Of course, we also check to make sure it's not dangerous.
Hi again, Koba-San!
I'm afraid there might be a slight misunderstanding regarding that patch.
It isn't actually intended for the DOVE SCSI interface board; it was designed for RAM expansions (for the 128K/512K) that use the same baseline logic as the DOVE MacSnap board, to be installed concurrently with the ROMINATOR I. Hope that helps clarify things!
In practice, that patch would be needed only on Mac 128K/512K systems with a RAM expansion board already installed where the ROMINATOR PCB fits.
Regarding a SCSI interface that also incorporates the ROMINATOR I, that is certainly possible, but it would require a new PCB design and new PLD logic.
Regards!
Hi @Builder68 ,
Ahhhh, it seems my previous comment was premature lol. I don't have the hardware to test patched ROMs, so I'll need to build the hardware myself. I intend to do so if I get the chance. I understood the general idea from your reply, but I'll reread the thread again, thanks.
