Radeon 9100 that I can't flash
indibil
Hello.
I recently acquired this 64MB Radeon 9100 (equivalent to a Radeon 8500LE), and just like I did with another 9100, I decided to flash it.
The previous one worked with the original ROM by adjusting the speeds to 250/250.
This graphics card came with a 64KB EEPROM, a PM39LV512, and since the original ROM is 128KB, I flashed it onto an AM29F010. I verified that the extra pin was traced on the PCB, and it was; it's routed.
After soldering the EEPROM and installing it in a G4 GE, which now has a flashed 8500, there's no image. Using an ATI Rage Pro PCI card, I can access the system profile and view the information, but it doesn't match what the 8500 displays.
Working Radeon 8500:
Radeon 9100 flashed:
Does anyone have the ability to review the two dumps I've attached and see if there are any incompatibilities? I also have the ROM that @joevt modified many years ago, but I don't know if it would be more compatible or if they're similar. I'm attaching it as well.
Thanks.
Looks like the ROM did not get applied correctly? Can you use a flashing utility to read the ROM?
What does .properties show for the GPU in Open Firmware?
Does it show that a PCI Option ROM exists and is 128K? If so, can you map it in Open Firmware and dump the hex?
Thanks for replying.
Before seeing your response, I decided to flash the original PC ROM to a 128kb EEPROM to see what Apple System Profiler would show, and it shows exactly the same thing as with the Mac ROM we saw earlier.
I use an Ati Rage Pro 1128 PCI to be able to view the 9100 AGP.
I used a 128kb EEPROM to try to patch it with the update released by ATI, but it doesn't work, and sometimes it shows this error:
Next, I performed a DUMP from OS9 using "ATI Multi Dumper", both from the PC ROM and the Mac ROM, soldered onto the board.
I've attached the files, but I think I've already located the problem: it's only accessing 64kb of the EEPROM, even though it has a 128kb chip.
On the PCB, there's a trace coming from pin A16, the only additional pin compared to the 64kb EEPROM, but I don't know where it should go.
Do you know where this A16 pin should be connected?
It appears that the EEPROM addressing passes through these ICs, which seem to be VCS74AK2R020, but I'm unable to find any datasheet with this part number.
A15 connects to pin 12, but A16 doesn't connect to any pin. Without desoldering it, pin 11 appears to be unconnected. Perhaps it should be connected there? Will I need to remove them to see where all the addresses go?
