Looking for Formac ProMedia 40 ROM Rip
@45ns: EDO 17ns = 59MHz
@40ns: EDO 15ns = 67MHz
@35ns: EDO 14ns = 71MHz
@30ns: EDO 12ns = 83MHz
@25ns: EDO 10ns = 100MHz
Urgh, so extrapolating the 60ns VRAM boards should be about 48MHz. Nasty. Hopefully the main chips are all the same grade and you can just swap in better VRAM.
Worth avoiding the 50 and 60ns cards though because they all basically cost the same, but it isn't worth buying replacement VRAM.
Bleh, I always forget that this era of stuff isn't just a machine code binary. That's a pain.
I think Forth is easier to read than machine code or assembly. My script converts fcode to Forth such that the reverse process should produce the same fcode (or slightly better fcode since my tokenizer uses single byte fcodes for the constants -1,0,1,2,3 instead of 5 byte literals).
I know this is probably a daft question, but is there a more comprehensive resource for OpenFirmware anywhere? All I have ever found are partial lists of common commands. I can navigate, modify NV stuff and poke around a bit, but I've never seen a "Learn how to make an OpenFirmware Forth Driver in 12 easy steps" book or anything similar.
Apple has some sample Open Firmware drivers in their PCI DDKs.
There's some links at https://apple.fandom.com/wiki/Open_Firmware
MacRumors has some Open Firmware related threads.
There's more links at https://wiki.osdev.org/Open_Firmware
Looks like https://www.devicetree.org/open-firmware/home.html has all the documents. Start with the IEEE 1275-1994 spec. Then PCI bindings. The16 color binding, 64 bit extensions (useful for G5?). etc.
Also, I'm getting strong "you need to go and grab one of your Beige G3's" vibes :LOL:
I hope to port it to older Macs such as my Power Mac 8600. It would be nice to include the Firewire Target Disk Mode code so I can connect all the drives in my Power Mac 8600 (including SCSI) to my modern Mac.
Should be GA-6 : it is a 2MB version of the S3 Virge card.
The ProMedia 20 and ProMedia 40 are the 2 and 4Mb Versions of the first Batch of cards (Rom version 1.0.6).
So the ProMedia 20 and 40 are both GA-6.
These ROMs have a pong game for Open Firmware:
Code:
GA5-ROM 1.5.6:CS_C852
GA5-ROM 1.5.7:CS_7087
GA5-ROM 1.8.0:CS_805D
GA6-ROM 1.2.6:CS_2876
GA7-ROM 1.6.5:CS_2670
GA8-ROM 1.7.0:CS_7265
GA8-ROM 1.7.2:CS_F187
GA8-ROM 1.7.6:CS_7277
GA8-ROM 1.8.0:CS_F548
GA10-ROM 1.6.4
GA10-ROM 1.6.9
GA10-ROM 1.7.1
GA10-ROM 1.7.2
GA10-ROM 1.7.3
GA10-ROM 1.7.4
GA10-ROM 1.8.0
GA10MT-ROM 1.6.4
GA10MT-ROM 1.7.1
ProFormance II Light v1.76
Have you a way to try that ? I will be fun to play pong on the open firmware from a graphic card
I extracted the code. To load the code:
On a Mac with a serial port:
- Type dl command to begin download.
- Paste the contents of the .4th file.
- Press Control-D to end the download. It executes the contents which in this case just adds words to the Open Firmware dictionary.
The dl command is nice because you can disable text pacing without it missing any characters.
A normal paste to Open Firmware using serial port requires a delay between characters because Open Firmware will often through away characters if more than 14 at a time are pasted.
dl works by accepting characters in a very tight loop and does not echo the characters back to the console which makes it faster.
On a Mac that supports loading a file in Open Firmware, you can use the load command to load either the .4th (Forth) file or the .fc (fcode) file.
Then open the gpu (doesn't need to be a Formac GPU). e.g. For Beige G3: " pci/@12" select-dev
Then do pong
Keys:
player 1 up:A down:Z
player 2: up:' down:/
new game: esc
end game: delete
The Forth file is 18,484 characters.
The fcode file is 3,727 bytes.
For a Power Mac 7500,8500,8600, the Open Firmware graphics driver for the built-in video requires a small patch to work correctly.Formac pong.png
I have looked through my stach of PCI graphics cards and found another ProMedia 40plus.
It has the 1.0.6 ROM, not the 1.2.6 ROM. My assumption was (based on a sample size of one ...) that every 20/40plus card would have the 1.2.6 ROM. This is not correct. I cannot really determine when the 1.2.6 ROM was released.
The 1.2.6 rom that i have on my nass shows a modify date of 18. December 1998.
You cannot make out the ROM-version of the expensive 35ns one on eBay
Here is another eBay 40plus with 1.0.6 ROM like my older Board.
GA6/X 1.0.6
Yesterday, i tested my original ProMeiad 20 with its original 1.0.6 ROM and software 4.2.1
The graphics chip is clocked @60Mhz with 45ns chips. A "flashed" PC-card with 40ns is working fine as well. 50ns or 60ns VRam will most likely not work. I have attached both rom versions (1.2.6 and 1.0.6) for those who don't want to search around.
"Bits and Bolts" is currently running a series where he modifies the VGA Bios of a Virge DX to do his bidding.
My 45ns PC card arrived yesterday. I need to do some house plumbing work tonight, but this and repairing a QuickSilver are this weekend's projects :)
The card I picked is quite a nice looking board compared to some of them.
I have experimented a bit and i come to the conclusion that Version 4.5.0 of the GA software will work fairly well with QD3D 1.0.6 and Virge Rom 1.0.6. Some 3D applications will not enable texture smoothing on the Virge. This makes it difficult to determine if 3D acceleration is enabled. The best way is to compare texture size since the Virge cannot display big textures. The GA control panel enables you to switch 3D acceleration off which is good for comparison. There is also some z-fighting and z-errors when the 3D acceleration is enabled. In System 7.6 there is seemingly no problem with the 3D extension being put in the wrong directory by GA4.5.0.
My (largely) working setup:
- PMac 8500 Mainboard
- PPC 604r@350MHz (chip-swap), no cache
- 128Mb RAM
- MacOS 7.6.1
- SCSI2SD
- QD3D 1.06
- Formac 4Mb Virge with rom 1.06 (40ns vram)
- GA-software 4.5.0 (my version from a 1997 system backup)
-Jonas
- 128Mb RAM
- MacOS 7.6.1
- SCSI2SD
- QD3D 1.06
-Jonas
Hum, just a thought - one quick check is the application "3D World" by MicroSpot will only do transparency with hardware acceleration if I remember correctly? Not sure if that is helpful / of interest.
Rom Version 1.2.6 seems to have blitter problems when GA_4.5.0 is used. With GA_5.2.2, everything is ok.
The Rave implementation for the Virge by Formac does not seem to support transparency or Phong-shading.
There are also some texture operations that the Formac Virge driver seemingly does not support.
It looks to me that a lot of QuickDraw 3D features are not compatible with the capabilities of the Virge.
I have seen an interesting description of how QuickDraw 3D applies textures:
TVP4020 PERMEDIA Programmer’s Reference Manual: page 109ff
My PC card came with a 27C256, and when I use a 512 kbit chip, address line 15 is tied to Vdd. I'm going to have to lift the pin and wire it to pin 105 on the Virge chip. Thankfully it is a corner pin.
First I'm going to work out where the existing trace from that pin goes in case there is a jumper to select or something.
Short answer... Yes, found a pair of straps that select A15 going to Vdd or to A15.
Woo!
Bit of soldering to do, but much better than a bodge wire and lifted pin :)
Well, almost. RAM is either too slow or there is a dry joint.
ROM works after moving the resistor on the card though!
Edit - I'm just waiting for the thermal glue on a heatsink to set some before I try it again. Might try with the older ROM out of curiosity.
The artifacts only happen while 2D acceleration is turned on.
Do the real cards work with Mac OS 9.2.2? Do they work in 2002 QuickSilvers?
I have not tested the card in 9.2.2 but only 8.6 and various 7.x versions. Those lines are somewhat visible on the flashed PC Virge card on start up but vanish when the resolution is switched. High resolutions can also result in strange behaviour when 3D is used. I typically test the QD3D cards in 640x480 @60hz 16bit and sometimes up to 1024x768.
To me it looks like the extended data out page-cycle is a bit too slow. Those lines are most likely the begin and end of a page burst. Maybe the Virge was run at lower voltage to reduce heat?
Try displaying a mpeg1 video in QT-player since the verge has a mpeg decoder integrated. You can spray compressed air onto chips (to cool them) if you think that there is a problem. The VRam is 60mhz capable in the data sheet.
It could also be a defective ram chip, flakey connection, a defective resistor, a defective GPU .... so many options ...
You could also add 2 100nf caps per vram from vcc to gnd for more stable local power.
