Looking for Formac ProMedia 40 ROM Rip
Perfect - a second card arrived here yesterday and had exactly this issue. Your timing is impeccable
Another difference is how the card selects a default setting. I find 1.0.6 selects a higher refresh rate by default which exceeds the capabilities of my elderly 4:3 LCD. This actually means I can't easily use 1.0.6 as most of not all of the boot key combinations also assume that my monitor is capable of high refresh rates. I sure there is a way around, but for now I just used the newer ROM.
Quite fascinating. I have the exact opposite situation. The 126 Rom seems to default to 75Hz while the 106 Rom defaults to 60Hz, in my case. I use an Extron RGB2HDMI 300A which can do almost everything you throw at it (15Khz - 120Khz no problem) and a Hauppauge standalone HDMI-recorder. The Extron RGB2HDMI 300A converts even the strange 31Hz resolutions of the 126 Rom but sadly shifts them so much to the right that i cannot get everything on screen.
That's really odd!
Yeah, I've barely used the 1.0.6 ROM because I just end up in unsupported modes :LOL: I'm using a 1280x1024 LG panel from the early 2000s. I need to replace the caps on the power board in my ViewSonic that can handle just about any video signal including from a Toby, which is useful (most LCDs don't like the output from a Toby).
