Which LC/Performa to buy?
tale
I've always wanted an old Mac, and I thought my iMac G3/Powerbook G4 12 could satisfy that need, but alas, I need something older. I have limited desk space (I even had to move my iMac G3 to the floor because I have no room for it), and as far as I know, the LC series is as small as it gets (compact macs are out of the question as I am not recapping an analog board). I've narrowed it down to either the LC 475/Performa 605, or the LC III, depending on which I can find on my local marketplaces and the RE-PC I live near (although their prices tend to be way too high). There are probably some other ones to consider that I haven't found yet, so I'm still considering my options. I could use some recommendations on models, information and things to look for about these, and other things, so please post some in the comments. I wish (or maybe there is and I didn't find it) a buyers guide for vintage macs in general (best I could find was the Mac84 series which I just finished watching). I would probably want to do some light gaming on this, and maybe even internet browsing through a blueSCSI I plan on getting.
If you don’t like the thought of replacing an analog board capacitor, you probably wouldn’t like dealing with a PowerBook and some of the issues that it has, especially if you buy one with screen troubles.
The LCIII is usually cheaper but the 475 is far faster. Alternately, buy a IIci. It’s not much larger and has a lot of expansion potential.
I have both an LCIII and a Quadra 605. The 605 is definitely more powerful, but it's still not enough to do some of the more demanding things. Like the next logic step after an LCIII is a PowerPC. Anything I do on a Quadra 605 is done better on a PowerPC, or not possible on an LCIII.
Any LC3 you buy will need capacitors replaced if they have not been done yet. Also make sure it has a hard drive as they are 50 pin SCSI and getting expensive to replace (also make sure the floppy drive works so you can install an OS 7.1 is nice). Getting ethernet is also a good idea if you are going to move files from your PPC machine to the LC.
Basically, any decent 030/040 that is local should work for you if want and old school Mac. A IIci/IIcx is also nice (same recap problem as the LC3) and they can be mounted sideways taking up less desk room then the LC3.
Get whichever one you can 😄 I am biased towards the LC475 - it is objectively the superior machine - but the LC III is also a very solid 68k machine in its own right. Plus many upgrades you make to an LC III will carry straight over to an LC475 if you pick one up in the future. Both use 72pin RAM, and if you recap or better yet do the Meanwell replacement for the PSU that also works great in both. BlueSCSI or other hard drive replacement can be moved over, any LC PDS card you pick up should also work. I'm pretty sure stuff like a Noctua fan upgrade, VRAM, and even the speaker can be moved over if you need to!
IIcx/IIcis are neat machines but I personally can't find much to do with NuBus, and the PSU is a way bigger pain in the ass to fix up! They do run System 6.0.8 though which neither of the two LCs mentioned support.
You can also use AppleTalk via serial ports to move files but I just shuffle SD cards and hda images around - I only have room for one machine set up at a time.
I have a Performa 637CD, and I have to agree, it feels like someone turned a 68030 up to 11
I considered those, but I feel like that would be far too much work. Screens, tiny broken parts, brittle plastic, batteries, etc.
Even the desktop systems require fussing to keep running: basically every system Apple made in the period being discussed will need capacitor work of some kind. The LC boxes in particular are notorious for issues with their power supplies and audio circuits. If you're not wanting to deal with that, spending the extra money on a recapped system (from someone reputable) might be prudent.
I can recap systems (although I'm not comfortable working around CRTs yet), although I may just get a restored system from someone (maybe RE-PC has them?) near me.
About the plastics, one of the great things with pizza box LCs is that cases and parts machines are not only easier to find than other Macs, but that the LC, II, III, and 475 all use the same footprints, with the main difference being the possible floppy drives. Luckily those are transparent to the machines' logic so you can swap them as well.
