I have a PB1400c & MBA M2. I've found the PB1400<->PCMCIA/CF<->CF\USB<->MBA M2.Hello. I have a beautiful PowerBook 1400c with OS8.5.
Is there a way I can transfer files such as txt or doc from the PowerBook to my current MacBook?
Thank you.
Unless he has an Ethernet PC card or some sort of serial to ethernet/appletalk device, that will be basically impossible.I use A2Server on a Raspberry Pi 2b. Everything on my network can see it, Apple IIgs - Mini, Win7 - Win10. If you want, you can mount M.2 drives to it with adapters for very large drives.
Thank you, but can you also show me how to strip all of that out?The CompactFlash adapter suggestion is nice, but those links are "hot links", with all kinds of tracking and advertising bull%#)! information in them. A shorter, safer link would be like this:
https://www.amazon.com/dp/B09NP3MJS2
https://www.amazon.com/SmartQ-C368-Multi-Card-Compatible-Supports/dp/B06Y1G18KS/
Furthermore, versions of Mac OS X roughly around 10.10 or higher aren't the best for working with old Mac file formats. While they can do it, there's better choices.
Networking is still the best way to go even today. Netatalk works great in virtual machines, although macOS host machines wouldn't be my first pick. You can get devices like the Farallon EtherMac PC card, like part number 590 or 595, which are still around. If the dongle is not included, don't buy it. Other stuff like Zip disks and Jaz things are kind of a thing of the past.
That would work...unsure with what he said that he has any other classic Mac, however.Sorry, I forgot to mention the LocalTalk bridge (control panel) which will run on any pre-Lombard Powerbook that has RJ45 Ethernet. 2400c, 3500C, Wallstreet. That is one way to connect your 8 Pin Din AppleTalk port to a RJ45 TCP/IP network.
I'm sure most people have Mac serial mini-DIN to USB converters in their back pockets!If it's just a txt or doc file, why not just over serial using something like Kermit?
I’ve also done it with a modem on each end and a null modem cable in between.I'm sure most people have Mac serial mini-DIN to USB converters in their back pockets!
The myriad ways of accomplishing something! You guys never cease to amaze me.I’ve also done it with a modem on each end and a null modem cable in between.
Mini-DIN to DE9 -> DE9 null modem cable -> DE9 to USB serial cable. Inexpensive and readily available in terms of kit... then simply make a serial connection. For instance, Kermit on the new Mac (install via Homebrew, free, pretty easy to use in Terminal), and Kermit on the old Mac (or ZTerm, or the like, that can use Kermit protocol).I'm sure most people have Mac serial mini-DIN to USB converters in their back pockets!
These days I sure didn't! I don't really know what counts as fast here, but I'm getting up to 8000 cps with kermit and 22000 cps using zmodem from this thing.I'm sure most people have Mac serial mini-DIN to USB converters in their back pockets!
