A Challenge: Plastic Macbooks for July
I'm trying to open one of the IMG files from Macintosh Garden's Quake download on my MacBook.
Finally opened the SEA file to reveal the two IMG files. Opening the file with Disk Utility reports that it is a legacy image file and should be upgraded.
How do I open the IMG file in macOS Catalina?
Coming back to this:
All of my MacBooks have arrived in the post! Perhaps strangely, they all smell kind of fishy.
I'm going to attempt some plastic welding after work and I'll let you know how it goes!
I recall that smell when I had one of the non-unibody MacBooks. I still smell it on my iBook G4 1.33ghz.
My 2009 MacBook has two small cracks on the rear display cover near the hinges. Hopefully I can do some plastic welding to help, but will wait until I hear of your results.
The easiest way is using Disk Jockey. The trickier way is to use Disk Utility's image conversion option to convert the image from NDIF to regular uncompressed DMG. The REALLY tricky way is to write an fsplugin for macOS to natively handle NDIF.
I tried Disc Jockey and could see the contents of the image files, but I needed to extract the contents of those files.
Instead of getting my iBook G4 out of the closet, I’m setting up SheepShaver and installing MacOS 8.1. I’ll mount the image files inside of it, run the installers and copy the files to a shared location.
Installed Quake in SheepShaver and copied the data files back to the MacBook. Setup QuakeSpasm using the data files and got it working.
One issue I see is that playing Quake for too long causes the MacBook to shut down due to overheating. This is with Macs Fan Control running the fan using a sensor-based value.
I may have to try this with the iBook G4 for giggles.
Does a powerbook 1400c count?😜
Lol! The PB1400c is a legend (I have one and love it), and I'm sure we're looking forward to some future exciting project involving it, but... unless it's running an Intel x86 Mac OS, then its posts belong in the PowerBook PPC forum..
Assuming it continues there, does it work BTW? It's an intriguing configuration though, slowest CPU alongside the best display; a decent amount of RAM and peripherals. Does it also have a video out at the back?
Still rocking my 2007 BlackBook 2.2GHz C2D running 10.7.5 with maxed out 6GB memory and an OWC Mercury Electra 3G 250GB SSD with dual boot MacOS & BootCamp (Win7). This one’s a keeper …IMG_1770.jpeg
My MacBook has made it to the pile of shame. Confirming all C2D motherboards fit the casing of 2006 - 2009 models? Appears either dead SATA or the cable for me. PATA works fine
I have to admit that I've been very negligent in participating in this challenge.
Perhaps if it were extended for another month or so, I could get my act together....
c
Nope. Tried a swap between an 06 and an 07 and there are minor differences. You might be able to force it to work.
I haven't tried it yet. I'll take a peek on ports next time I pull it out.
How did the plastic Macbook challenge go in July?
I'm continuing to use mine into August, because it's a great bridge machine between my PowerPC Macs (PB1400c/166 and B&W G3/350). I can do rapid transfers between USB and the G3 (or USB->Compact Flash<->PB1400c); and prepare CDs for both. I also upgraded it to 3GB (wooo). The MBc2d is fast enough for posting on the 68KMLA, but handles archaic disk formats better. Having said that, I think my Mac mini G4/1.33 would just about be able to do all of that too, the MacBook is a more convenient setup. FYI: the PB1400c/166 runs Mac OS 8.1 (or 8.6 on CF) and the G3 runs Mac OS 9.2.2/Mac OS X 10.3.
Sounds fun. Great configuration for bridging but also convenient. I never owned a Macbook but several Mac Mini C2D to do roughly the same. Was it a contest is there a winner ?
