If it's dark, my guess is there's still a layer of stuff (carbon?) on it. Polish is not going to be abrasive enough to take that material off - you'll probably be sitting there polishing for a really long time. Might want to get a light sand paper (800 grit) and try a small area and see if you can get the shine back. If that works and is silver, you'll probably want to go 800 grit -> 1200 grit -> 1500 grit -> 2000 grit -> 2500 grit and at that point if it's silver but not shiny enough for you, you can pull out the polish at that point.
I'm leaving mine the darker slightly gunmetal color
It's inside the case and I just don't have enough patience right now to restore that piece to a bright silver shine.
