jmacz journey
jmacz
68020
As 2023 began, I stumbled upon a listing for a Quadra 700 while searching for non-related camera gear. Although I'd been using modern Macs for quite some time, I hadn't thought at all about the 68K Macintoshes I had spent a ton of time with growing up, the 512K, SE, Macintosh IIs, Quadras. I then left for an extended time working on Linux, NextStep, BeOS, Windows, Solaris. Then came back to Apple with the modern Macs in the mid 2000s.
That unintended find of the Quadra in January turned into 8 months of fun rediscovering that spark from decades ago. Starting this thread really for myself to keep track of all the adventures this past year, and the ones to come in the future.
January, The Return to 68K (documented restoration here)
index.php
Power supply rebuild and conversion to ATX, fixed a bunch of physical cracks in the case.
January, Recapping of Macintosh 16" Color Display (documented here)
index.php
Recapped the monitor which resolved weird shadow issue.
You're having fun! I'm enjoying your writeups and diagnosis threads, even if I don't usually have much to add to them.
Likewise I am enjoying your write-ups, and the quality of your work is really impressive. You have more patience than I do as well. Please keep it up as long as you're enjoying it!
Ok great... addiction... thanks to some nudging from @3lectr1cPPC, I've got two 5300s on the way (a 5300cs and a 5300c) both not working. Two more things for the back log.
From the recent lot I picked up, there was a battery bombed IIci... this one's going to take some work.
Need to get a new oscillator Y6 and a new crystal Y5. The battery holder has to go. D7/D8 transistors probably need to be replaced. I am not sure UK14 RTC is going to be salvageable. I need to clean it up and see how much of the legs are left. And then there's some corrosion on the ROM chip. And that's not the end of it:
It also has cap caused corrosion. A chip already fell off (UD13) and UE13 is about to fall off. UB13 also not looking good. And there's some damage to the pins on UA13. At least UB13, UD13, UE13 are all easily replaceable and cheap. But UA13 and UK14 from the other picture I think might be Apple specific chips? I'm not in a hurry to fix this so will have to keep my eyes open for a donor if those chips are bad.
