Macintosh IIcx jumpers at W3
I've just acquired a IIcx logic board and have been looking it over.
There is a jumper labelled W1, which I understand is for selecting a ROM SIMM vs the onboard ROM, just like the IIsi and IIci.
There is also a pair of jumpers labelled W3. Anyone know what they do?
They disconnect /BR and /BG. There's some note in apple documents as it being part of the burn-in testing and to never remove in operation. Had the same question myself.
There’s also W2, unpopulated…
Ah, interesting! I was too blind to find it myself in the Bomarc schematics. The AI assistant in Adobe Reader was completely useless, too:
So instead, I used @max1zzz's IIcx reloaded board file to trace out where they go, and sure enough, there it is in the Bomarc schematics. It's hooked up to pins 5, 6, and 7 of UH6 (VIA2).
These pins are also known as PA3, PA4, and PA5 of VIA2 and also go to pins on the GLU chip. Luckily, Guide to the Macintosh Family Hardware 2nd edition tells us what they are. They are interrupt request lines for expansion slots $C, $D, and $E.
And more useful info from the same book...
So after all that, I can say that it looks like they are the IRQ lines for the three other NuBus slots that aren't available on the IIcx, since the NuBus slots it actually has are $9, $A, and $B.
Hahaha. That’s hilarious.
I guess AI isn’t quite ready to take over the world, yet…
So sort of something vestigial, when they developed the IIcx board as a cut down design of the IIx?
I think that's a good way to put it!
I wonder if you could use that header in conjunction with one of the actual NuBus slots to make a crazy frankenstein NuBus card that brings out the extra NuBus slots somehow (externally to another enclosure or something?). It looks like the only thing unique between the different slots is that IRQ line as well as whether certain pins are floating or grounded, which must be how the card knows which slot it's in. Maybe it would be bad for the integrity of the signals, though. I dunno.
Based on the Bomarc schematics, I'm assuming that on the IIci, unpopulated J15 (near W1) is the same concept.
Those IRQ lines are interesting. I was debating making a CPU-socket 30Video card for my personal use on an IIcx board I have, but the lack of IRQ requires resorting to shenanigans like triggering it off a timer or hijacking the IRQ signals as SE cards must do.
With those IRQ lines you could make PDS-type IO cards for the IIcx also, but due to the nubus slots using the addresses usually used by PDS you'd still need nonstandard decoding.
