Yep, that's what I typically use.Is 30 AWG Kynar wire sufficient, or what would you recommmend?
You're absolutely correct, those pads were burned off, before I started digging at the board looking for copper under there. Should've left it like this:When I say I think they're gone, I mean it looks to me like the pads came off with the part. I hope I'm wrong!
Everything was going really well, until I plugged it in.
Seems I've joined the simasimac club, except I get no chime, just an opening pop/crack as if a sound might begin to play (very brief pop/click), and then only this.
The chains.
Do you get the chime at least? I used the zoom feature on my ancient phone, to take those close up pics of the UE8 chip. Can you get some good pics of your row of Uxx chips, that UE8 is in? You're welcome to post some pics in here, if you feel like it.I have the same simasimac pattern. I also ordered new RAM from OWC but that didn't fix the problem. Might just send it to someone who can take a look and troubleshoot it.
Looks like only the tube packaging has gone obsolete; the LS166 in 16-SOIC is still available in tape packaging, in quantities down to 1. Eventually the day will come for all these SOICs, but it hasn't come for this one yetEDIT: Just now received an email from DigiKey, telling me the UE8 I ordered, is now obsolete - get them while you can.
SN74LS166AD | DigiKey Electronics
Order today, ships today. SN74LS166AD – Shift Shift Register 1 Element 8 Bit 16-SOIC from Texas Instruments. Pricing and Availability on millions of electronic components from Digi-Key Electronics.www.digikey.com
Yes, noticed there was a substitute still available, and deleted that edit.Looks like only the tube packaging has gone obsolete; the LS166 in 16-SOIC is still available in tape packaging, in quantities down to 1. Eventually the day will come for all these SOICs, but it hasn't come for this one yet
I looked all through the SE/30 schematics, and could not find UE8 listed, in order to determine where pin 8, 10, and 14 were supposed to connect to.
The new LS166 UE8 8-bit shift register will be here Saturday. If this isn't the entire problem, it's a good place to start with.
These simasimac failures must have a high probability of occurrence due to the corrosion of the old caps in the surrounding areas of the leaks. I'll be putting that hypothesis to the test, beginning this Saturday, hopefully.
Its on page 5 of the schematics - the page is titled "Video Interface". UE8 is kinda hard to find because its the only chip whose label is to the right of the pinout versus the top. Its the chip labeled "Shift Register" on the far right of the page, halfway down - its section "B5" of the page.
That's a very clean looking board. I'm a little worried about Y3, though. Are its leads intact? Is it touching UE10?
You have an early board with a socketed ‘gold-top’ CPU. For some reason, the PCBs on those are really sensitive to heat as well (I didn’t know about UV). I’ve worked on those carefully with a solder iron and sadly couldn’t avoid discolouring them.Learned that UV light can sunburn a PCB, this one upset me pretty good, had to walk away from this for a bit.
With the amount of corrosion you can see underneath the pins it'd probably be a good idea to just remove the entire chip from the PCB and give it a good cleaning underneath.
Good to know. If you look at Post #74, above, you can see the traces have changed to an amber color immediately following the extended UV treatment, the UV could've heated the board too I guess.You have an early board with a socketed ‘gold-top’ CPU. For some reason, the PCBs on those are really sensitive to heat as well (I didn’t know about UV). I’ve worked on those carefully with a solder iron and sadly couldn’t avoid discolouring them.
