Help to identify IC Supermac 8*24 PDQ
Hi guys, I've a faulty 8*24 PDQ, provably is something around U24 or the U24 itself. I can't find anything about this card: schematics, parts list and so on...
The IC is a clk-02 9146 (see the photos), but I dont know what it is. Maybe a clock buffer but I dont know.
Any help ?
Thank you so much
Its probably the dot clock generator if it is any help.
From a quick check it seems to me that the pinout is not compatible. I don't know if it's because one chip is clk-02 and the other clk-03. But anyway it's a starting point...
That's the dot clock generator. What problem are you having with the card? If it creates a syncable image at all, that chip is doing its job.
By way of speculation, it's likely a remark of something off-the-shelf. Programmable PLLs were pretty new in the early 90s so there weren't a lot of options. Apple used the National Semiconductor DP8531 (Q700/900/950) and DP8534 (Wombat) and the Sierra Semiconductor SC11412 (Q605/LC475/LC575), to give some popular examples.
At the beginning the card generated a wobbly image which was stabilized by touching the R39 resistor. Now she is completely dead. There was a moment that generated something by holding down the IC. I reworked all the soldering and checked the traces... I probably damaged the IC further by doing some checks on the traces and shorted it out. All the components around are ok...
