Last I checked, Herb was out of stock.
Herb just restocked! I purchased one... although there isn't many, Herb had to get the pins repaired. Hence why I posted here. Herb's an amazing detective for this stuff.If anyone has a spare they'd kindly let go? I am doing a scratch built Amiga 4000 from bare motherboard and accelerator card.
I would love to hear your advice on proper heatsinks! I have an (evidently) non-genuine '040/40 that's unstable at 40 MHz. It reports to have both FPU and MMU, but I've stuck a cheap Amazon heatsink and it overheats and barfs. Would you have a link to a proper heatsink?Finding a genuine non-LC 040 in itself is a win anymore. With a proper heatsink, most that I've tested can go to 40MHz without adverse effects thermally. I think what I might do, if ever spare time wills itself into being, is do general system stability tests (in another thread).
Hey, thanks for the recommendation! I've just looked it up, and I've just noticed that you can get this stuff in multiple thicknesses. Would you have any recommendations/knowledge on why this is the case/what to get?Double-check that the heatsink's adhesion is actually thermal. I've received heatsinks from Amazon sellers with ordinary double-sided sticky tape as well as 3M coated tissue tape (not thermal tape). That will act as an insulator, which is the opposite of what you want.
In the picture above, I peeled off the tissue tape, cleaned the part with isopropyl alcohol, and applied a ThermalRight thermal pad.
All the tests were with no heatsink at all.What kind of heat sink are you running during these tests? My current chip (early 25 mhz) runs hot enough I can't barely touch the sink.
It's impossible to tell, because there is no saying you'll get the one pictured.Here's an eBay seller in China offering chips with mask 02E31F. Do these look legit?
Motorola 68040 XC68040RC33M MC68040RC 02E31F 33MHz Vintage CPU PGA | eBay
Find many great new & used options and get the best deals for Motorola 68040 XC68040RC33M MC68040RC 02E31F 33MHz Vintage CPU PGA at the best online prices at eBay! Free shipping for many products!www.ebay.com
This… Also the shipping times are so extreme sometimes that you'll miss the feedback window (and sometimes the return window). Not talking about that seller specifically, just in general.It's impossible to tell, because there is no saying you'll get the one pictured.
I need to self-crit on this. I'm making strides to move beyond my weird obsessions. I honestly, now, couldn't care lessofftopic
so the V versions can do either 3.3V or 5V? I was told they could only do 3.3V, which is why people weren't using them. Sorry if I've been parroting more anecdotal BS by saying they can't. Or maybe I'm reading that wrong, but the verbiage leads me to believe that they can indeed run with either 3.3V or 5V.MOTOROLA M68040 USER’S MANUAL C-1
APPENDIX C
MC68040V AND MC68EC040V
The MC68040V and MC68EC040V are Motorola’s 3.3 volt, static versions of the MC68040 third-generation, M68000-compatible, high-performance, 32-bit microprocessor. They require a 3.3V power supply providing over 50 percent reduction in power consumption compared to a 5.0V device. The maximum power used at 3.3 volts is 1.5 watts at an operating frequency of 33 MHz. They also have a low-power stop mode. Once in this state, both devices remain quiescent, consuming less than 330 μW of power. The low-power usage of these microprocessors makes them an ideal choice for portable computing and power constrained applications.
The MC68040V programming model, data formats and types, instruction set, caches, and MMUs are the same as those described for the MC68LC040 in Appendix A MC68LC040. The MC68EC040V programming model, data formats and types, and instruction set are the same as those described for the MC68EC040 in Appendix B MC68EC040. However, both devices contain additional features:
• For the MC68040V, all differences that exist between the MC68LC040 and the MC68040, as described in Appendix A MC68LC040, also apply to the MC68040V. For the MC68EC040V, all differences that exist between the MC68EC040 and the
MC68040, as described in Appendix B MC68EC040, also apply to the MC68EC040V.
• Both devices operate to 0 Hz and can accept 3.3V or 5V input.
• Both devices have a new processor status state, low-power stop mode, indicated when PST(3–0) = $6.
• There is no PCLK or TRST pin on either device.
• Both devices provide three new pins, system clock disable (SCD), low frequency operation (LFO), and loss of clock (LOC)
